Free trees!!!!
Hi
We've just had Inventor installed at work. We design sewage treatment works, so we're doing the buildings, tanks & pipework in 3D.
Has anyone got any 3D lanscaping models, trees, bushes &c, or know where I can find some?
People & vehicles would be handy too!
Cheers
H:wink:
What are the acceptable file formats you can use with Inventor?
I don't get the impression that Inventor would be terribly useful for designing at that level (I'm sure it can, just not how I generally envision the program). You may be able to find something if ReMark is bored enough to scour cben though.
.ipt - Inventor Part File
.iam - Inventor Assembly File
.idw - Inventor Drawing File
.dwg - Autodesk Standard DWG
I'm not sure if the last two would be actual models though. I'm not sure how well Inventor would play with a DWG model, but it "should" be able to in some way at least.
Apparently, filetypes can be:
Pro/ENGINEER
Parasolid
SolidWorks
UGS NX
SAT
STEP
IGES
It's all a bit Greek to be, I only drive the thing, I haven't a clue what goes on under the bonnet!:oops:
So you thought you would harass me? I'm on to you Hoozin!
