Jim Clayton Posted March 28, 2019 Posted March 28, 2019 I'm in an argument with my co-workers and determined to prove them wrong. CAD dept. is split up into two sides. One side works off of their C-drive. The other side works off of the N-drive. I have worked from both. When checking drawings into Vault, the N-drive side says that they have to go thru a series of folders/paths before they can check drawings in. I swear that I have done this exact thing before and all I get when trying to check drawings in is the "Check In" pop up box. Is it possible to check drawings in from the N-drive without searching for a path? Just receiving the prompt like you do if you work off of C-drive? If so, what needs to be done to make this happen. Thanks for the help. Quote
