Sheet Set Custom Field Issues
Hi there,
I have been creating a Sheet Set template for my company and have already read Sheet Happen, so now I am here hoping one of you have had a similar issue. Here it is...
I created Custom Properties for multiple fields for each of our title blocks such as Consultant types, address and phone numbers ect. All these fields worked fine when designing the template, but as soon as I try to use it in a real project none of the fields do anything unless they are set to current sheet such as my page number and titles.
I discovered that when I go into the edit fields and select the only Field Name that has the custom fields, which is Sheet Set, it is set to "Template" rather then the new project name.
I was worried about this when I was building this up, but thought that the CAD Gods would have figured that we need to be able to use these custom fields for varying projects and are not going to want to rebuild them each time, thus defeating the purpose. So how can I make my fields update to the CurrentSheetCustomProperties which does not seem to exist?
Thanks,
Very frustratedly
Eric:huh:
