Selection of items by volume
pizarro
  • Obtain selection set of all 3D Solids (ssget)
  • Iterate over selection set (examples)
  • Convert each entity to a VLA Object (vlax-ename->vla-object)
  • Query Volume property of the VLA Object
  • Use an if statement with test expression to check if volume is within range
  • Construct new selection set (ssadd) of target entities, or remove entities which do not meet the criteria from the set (ssdel)
  • Select resulting set (sssetfirst)
Edited by Lee Mac
(vl-load-com)
;; Select Solids By Volume
(defun c:ssbv ( / ss min max solids)
  ;; selects all solids
  (setq ss (ssget "X" '( (100 . "AcDb3dSolid") )))
  ;; user imput: min & max volume
  (setq min (getreal "\nMinimum volume: "))
  (setq max (getreal "\nMaximum volume: "))
  (ssvb min max ss)
(defun ssvb (min max ss / i solid boxObj volume solids)
  (setq i 0)
  (setq solids (ssadd))
  (repeat (sslength ss)
    (setq solid (ssname ss i))
    (setq boxObj (vlax-ename->vla-object solid))
    (setq volume (vla-get-Volume boxObj))
    (if (and (>= volume min) (<= volume max) ) (progn
      (ssadd (ssname ss i) solids)
    (setq i (+ i 1))
  (if solids
    (sssetfirst nil solids)
okay, thanks.
(vl-load-com)
(defun c:ssbv ( / ss mini maxi solids)
  ;; user imput: mini & maxi volume
  (setq mini (getreal "\nMinimum volume: "))
  (setq maxi (getreal "\nMaximum volume: "))
  (ssvb mini maxi ss)
(defun ssvb (mini maxi ss / i solid boxObj volume solids)
  (setq i 0)
    (if (<= mini volume maxi) (progn
    (setq i (+ i 1))
  (if solids
