JoeyG_77
Change Layers inside a Block
JoeyG_77
Hey everyone ... Im looking for a lisp that would take a block open it and change all the layers & line types to "bylayer" & then change it to a specific layer and close the block after editing it.
Thanks
Joey G
Share this post
Link to post
marko_ribar
I had this in my library - modified it from ByBlock to ByLayer for your purposes... Untested though...
(defun c:BlksByLayer ( / *error* BlkByLayer *adoc* ss i lst )
  (vl-load-com)
  (defun *error* ( m )
    (vla-endundomark *adoc*)
    (if m
      (prompt m)
  (defun BlkByLayer ( objSelection / blkdef )
    (if (= (type objSelection) 'ENAME)
      (setq objSelection (vlax-ename->vla-object objSelection))
    (if (wcmatch (strcase (vla-get-objectname objSelection)) "*BLOCK*")
      (if (and
            (setq blkdef (vla-item (vla-get-blocks *adoc*) (vla-get-name objSelection)))
            ;;;(= (vla-get-isdynamicblock blkdef) :vlax-false) ;;; - if you need to process dynamic blocks as well - if you don't remove comments
            (= (vla-get-isxref blkdef) :vlax-false)
            (not (vl-position (vla-get-name objSelection) lst))
          (setq lst (cons (vla-get-name objSelection) lst))
          (vlax-for objBlock blkdef
            (vla-put-color objBlock 256)
            (vla-put-linetype objBlock "ByLayer")
            (vla-put-Lineweight objBlock -1)
  (setq *adoc* (vla-get-activedocument (vlax-get-acad-object)))
  (if (= 8 (logand 8 (getvar 'undoctl)))
  (vla-startundomark *adoc*)
  (if (setq ss (ssget "_:L" '((0 . "INSERT"))))
      (BlkByLayer (ssname ss (setq i (1- i))))
      (entupd (ssname ss i))
  (vla-regen *adoc* acactiveviewport)
  (*error* nil)
HTH., M.R.
Share this post
Link to post
JoeyG_77
Marko ... Thanks for the response ! It worked great to change everything to bylayer but I needed it to change it to a specific layer after it changed to bylayer .
Thanks for the help
Share this post
Link to post
marko_ribar
Try changing this part :
To something like this :
      (entupd (cdr (assoc -1 (entmod (subst (cons 8 "LayerName") (assoc 8 (entget (ssname ss i))) (entget (ssname ss i)))))))
Share this post
Link to post
