Sign in to follow this
GLORY
Multiple CTAB
GLORY
Hello,
Need some help regarding the code  I found. What it does is copy a single layout and increment it based on the last character of the last layout name, if its Alphabet, the new layout name will be the next character of the alphabet and same with numbers. All I want is to add a variable if want to copy it depending on the number of copies i want.
Here's the code...
(vl-load-com)
  (setq m:err *error* *error* *merrmsg*)
  (setq layout_names (LAYOUTLIST))
  (setq old_layout_name (getvar "CTAB"))
  (if (member old_layout_name layout_names)
      (setq new_layout_name old_layout_name
           last_layout_name new_layout_name
            buf "" i (strlen new_layout_name))
      (while (or
               (member
               (setq new_layout_name (incsuff new_layout_name 1 Only-number))
               layout_names
               (null new_layout_name)
        (if new_layout_name
          (setq last_layout_name new_layout_name)
            (if (= 0 i)
            (setq buf "" new_layout_name (strcat old_layout_name "-0"))
            (setq buf (strcat buf  (substr old_layout_name (strlen old_layout_name)))
                  new_layout_name (substr old_layout_name 1  (setq i (1- i)))
      (setq new_layout_name (strcat new_layout_name buf))
      (setq i (vla-get-TabOrder (vla-item (vla-get-layouts(vla-get-activedocument
      (vlax-get-acad-object))) last_layout_name)))
      (command "_.LAYOUT" "_C" old_layout_name new_layout_name)
      (vla-put-TabOrder (vla-item(vla-get-layouts(vla-get-activedocument
      (vlax-get-acad-object))) new_layout_name) (1+ i))
      (setvar "CTAB" new_layout_name)
    (alert (if(= (getvar "DWGCODEPAGE") "ANSI_1252") "Not Allowed in Model Space."))
Share this post
Link to post
BIGAL
Quick and dirty try this
(vl-load-com)
 (defun addlayouts ( )
      (while (or
               (member
               layout_names
        (if new_layout_name
            (if (= 0 i)
(setq x (getint "Enter how many layouts to be added"))
(repeat x)
 (addlayouts)
Share this post
Link to post
