dancohen250 Posted April 18, 2019 Posted April 18, 2019 Hye, I Have a Lisp Routine that copy blocks (not objects) from xref's this routine let me select only 1 block and i would like to select more or even previews selection in autocad memory. also, it woud be great if it possible to choose a nested level. Thanks for any help! (defun c:nrefcopy ( / ns e p ) (setq e (cadar (reverse (setq ns (nentsel "\nPick nested reference to copy from parent reference"))))) (setq p (cadr ns)) (command "_.-REFEDIT" "_non" p "_O" "_N" "_non" p "" "_Y") (command "_.COPY" "_non" p "" "0,0" "0,0" "") ;(while (< 0 (getvar 'cmdactive)) (command "\\")) ..? did not understand what it does..? (command "_.REFSET" "_R" (entlast) "") (command "_.REFCLOSE" "d") ; discard all changes, PICK THE ITEM BUT DO NOT SAVE, POSSIBLE FILE PROP REVISIONS ETC., ITS SAVER (command "_.move" p "" pause) ; HIGHLIGHT IT AND BEGIN A MOVE ACTION (princ) ) Quote
BIGAL Posted April 19, 2019 Posted April 19, 2019 Lee-mac steal.lsp may be useful it can be called from a lisp with no user interaction an xref is another dwg. Quote
