ramimann
ALIGN TEXT TO A PICKED POINT
ramimann
Hello Everyone
I need a code that can align text (from X or Y of insertion point) to "x" or "y" of a picked point.In fact, when I pick a point,the word will move to that X,maintaining the Y coordinate or to the Y of picked point,maintaining the X coordinate. Does anybody have such a lisp?
Thanks in advance
Share this post
Link to post
eldon
Almost like Move with Coordinate Filters, but automated to save fingerwork.
Edited by eldon
amplification
Share this post
Link to post
ronjonp
Posted HERE too.
Share this post
Link to post
BIGAL
Yeah Cab offered a lot of solutions.
Share this post
Link to post
myloveflyer
(defun c:Text_Alignment (/ selobjs oldcmdecho)
  (setq oldcmdecho (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq selobjs (ssget '((0 . "TEXT"))))
  (process selobjs)
  (setvar "cmdecho" oldcmdecho)
(defun process (selobjs      /        amode     apnt    apnt_x
        apnt_y      count        objname   vlaxobj    MinPoint
        MaxPoint  minext   maxext   ext_l    ext_r
        ext_m      tpnt
  (initget "L M R")
  (setq    amode (getkword
        "\nSelect alignment [Left Align (L) / Center (M) / Right Align (R)] <Center >:"
  (if (not amode)
    (setq amode "M")
  (initget 1)
  (setq apnt (getpoint "\nSelect the alignment point of the horizontal alignment direction:"))
  (setq    apnt_x (car apnt)
    apnt_y (cadr apnt)
  (vl-load-com)
  (setq count 0)
  (repeat (sslength selobjs)
    (setq objname (ssname selobjs count))
    (setq vlaxobj (vlax-ename->vla-object objname))
    (setq MinPoint (vlax-make-variant))
    (setq MaxPoint (vlax-make-variant))
    (vla-GetBoundingBox vlaxobj 'MinPoint 'MaxPoint)
    (setq minext (vlax-safearray->list MinPoint))
    (setq maxext (vlax-safearray->list MaxPoint))
    (setq ext_l (car minext))
    (setq ext_r (car maxext))
    (setq ext_m (+ (/ (abs (- ext_l ext_r)) 2) ext_l))
    (cond
      ((= amode "L")
       (setq tpnt (list ext_l apnt_y))
      ((= amode "M")
       (setq tpnt (list ext_m apnt_y))
      ((= amode "R")
       (setq tpnt (list ext_r apnt_y))
    (if    tpnt
      (command "_move" objname "" "non" tpnt "non" apnt)
    (setq count (1+ count))
This program only aligns text (no text spacing is considered).
Edited by myloveflyer
Share this post
Link to post
ramimann
On 5/2/2019 at 7:32 PM, eldon said:
Almost like Coordinate Filters, but automated to save fingerwork.
Yes..
Share this post
Link to post
ramimann
Thanks Everybody
"Text_Alignment" by Myloveflyer is very good but it lacks the vertical alignment😊..Please
Share this post
Link to post
Lee Mac
The following is loosely based on my Align Text program - the commands are ATX & ATY:
(defun c:atx ( / l )
    (if (setq l (getinput))
        (apply 'at (cons (lambda ( a b ) (list (car a) (cadr b) (caddr b))) l))
(defun c:aty ( / l )
        (apply 'at (cons (lambda ( a b ) (list (car b) (cadr a) (caddr b))) l))
(defun getinput ( / s p )
    (if (and (setq s (ssget "_:L" '((0 . "TEXT"))))
             (setq p (getpoint "\nSpecify alignment point: "))
        (list s p)
(defun at ( f s p / i x )
    (repeat (setq i (sslength s))
        (setq i (1- i)
              x (entget (ssname s i))
        (at:puttextinsertion (f p (at:gettextinsertion x)) x)
(defun at:getdxfkey ( enx )
    (if (= 0 (cdr (assoc 72 enx)) (cdr (assoc 73 enx))) 10 11)
(defun at:gettextinsertion ( enx )
    (cdr (assoc (at:getdxfkey enx) enx))
(defun at:puttextinsertion ( ins enx )
    (   (lambda ( key )
            (if (entmod (subst (cons key ins) (assoc key enx) enx))
                (entupd (cdr (assoc -1 enx)))
        (at:getdxfkey enx)
Share this post
Link to post
ronjonp
This same problem was posted at TheSwamp and Autodesk as well...
Not what the OP was asking for but might be useful to someone. Aligns to X/Y picked point based on closest bounding box edge.
(defun c:xy (/ i k ll p p2 s ur)
  ;; RJP » 05.08.2019
  ;; Align selected objects by closest bounding box edge to picked point
  (or (setq k (getenv "AlignStuff2")) (setq k "X"))
  (cond
    ((and (not (initget "X Y"))
	  (setq	k (cond	((getkword (strcat "\nAlignment [X/Y] <" k ">: ")))
			(k)
	  (setq p (getpoint "\nPick an alignment point: "))
	  (setq s (ssget ":L"))
     (setenv "AlignStuff2" k)
     (if (= "X" k) (setq i car p (i p)) (setq i cadr p (i p)))
     (foreach b	(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
       (vla-getboundingbox b 'll 'ur)
       (setq p2 (mapcar 'vlax-safearray->list (list ll ur)))
       (setq p2 (car (vl-sort p2 '(lambda (r j) (< (abs (- p (i r))) (abs (- p (i j))))))))
       (vlax-invoke b 'move p2 (subst p (i p2) p2))
(vl-load-com)
Edited by ronjonp
Share this post
Link to post
myloveflyer
        (list s p)
        (setq i (1- i)
    (   (lambda ( key )
        (at:getdxfkey enx)
Cool,Lee
Share this post
Link to post
myloveflyer
  ;; RJP » 05.08.2019
  (cond
			(k)
(vl-load-com)
Well Done,RJP
Share this post
Link to post
Lee Mac
9 hours ago, myloveflyer said:
Cool,Lee
Share this post
Link to post
ronjonp
12 hours ago, myloveflyer said:
Well Done,RJP
Thanks!
Share this post
Link to post
