AbdRF Posted May 2, 2019 Posted May 2, 2019 Hi all, I want to plot the multiple dwgs (only model space) into one pdf for which I am using the batch plot. I have created a custom plot style table as per the requirement which I am able to use when plotting single sheet only. I want to use the same created custom plot style for batch plotting. Also, how can we control what is plotted for each dwgs in batch plotting? I mean window selection for plotting. Any suggestions? Thanks Quote
maratovich Posted May 2, 2019 Posted May 2, 2019 It is necessary to clarify: Do you have all the title blocks only in the Model? Do you want to print from Model or create layouts? Attach an example of your file. Quote
AbdRF Posted May 3, 2019 Author Posted May 3, 2019 @maratovich I am plotting directly from model space and the title blocks are both in the model and layout. Drawings are 2D floorplans. Quote
maratovich Posted May 3, 2019 Posted May 3, 2019 Attach an example of your file. https://autode.sk/2IrfN8M Quote
AbdRF Posted May 8, 2019 Author Posted May 8, 2019 Hi, @maratovich Thanks for looking into. I have found a solution to this one in this post https://forums.autodesk.com/t5/autocad-mechanical-forum/publish-batch-plot-vs-print-page-setup-plot-style/m-p/5299877#M17559 Quote
maratovich Posted May 8, 2019 Posted May 8, 2019 Good. But do not forget this forum, you will come up with a new question, because there will be more questions further. And then we go back to the beginning. Quote
