layering
cadmesomehelp
is there a way to make an automatic button show up on the ribbon, every time i open up autocad that will insert all my standard layers. my old place of work had this in place and im not sure how to do it. it was so helpful! can any of you help me with the steps to make this happen.
Start a new drawing, insert your layers from another drawing and then save this blank drawing as your new start-up template ;)
@f700es That doesn't work if you start with existing drawings from others. I don't know what @cadmesomehelp is doing, but if he/she needs to insert a standard set of layers into any drawing, you could use a lisp file or a script file, or simply insert a blank drawing that contains all of the layers.
Did not see that the OP mentioned using "others" drawings. Any how it is pretty much the same thing as inserting a blank drawing that has the needed items and you stated.
Thanks for the correction, as always.
Another option is to export the desired drawing's layer state to a file. A button script can then import this file.
1 hour ago, RobDraw said:
Design Center is another option.
Actually this is what I meant by " insert your layers from another drawing " but I clearly wasn't specific enough.
I wasn't sure exactly what you meant but I thought it might be copy/paste objects on the desired layers or insert the other file as a block and delete. Sorry to steal your thunder.
Try this BUT note if you have custom linetypes extra code required. Change output file location to suit.
(alert "Only Acad line types supported\n\nload custom linetypes before running")
(setq fname (open "c:\\acadtemp\\makemylayers.scr" "W"))
(vlax-for lay (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
(setq ans (mapcar '(lambda ( p ) (vlax-get lay p)) '(Name color Linetype)))
(write-line (strcat "-layer M " (nth 0 ans) " C " (rtos (nth 1 ans)2 0) " " (nth 0 ans) " LT " (nth 2 ans) " " (nth 0 ans) " ") fname)
(close fname)
Edited by BIGAL
