Map 3D Toolset Tools for Regular AutoCAD Objects [Part Two]: Boundary Trim
The AutoCAD Blog
Boundary Trim
In the second installment of our series on time-saving tools in the Map 3D toolset, we’ll take a look at some additional cleaning up. Be sure to check out the first article that will set you up for success with Boundary Trim.
Boundary Trim
Let’s say in the same file we used in the first article of the series, we only need some of the contour in this drawing—not the entire file. With regular AutoCAD, this would be difficult to clean up. You could create a rectangle, run the trim command, and then select the object as the cutting element. But then you would have data outside the rectangle that you would have to manually erase.
Boundary Trim to the rescue! This tool is just plain awesome. If you need to “trim out” an entire area of your drawing or trim inside an area of your drawing, this tool does exactly that.
Navigate to the Ribbon: Tools > Map Edit panel > Boundary Trim. This tool is really easy to use. Simply define your boundary manually, or select an object in the drawing. Then simply select the Trim method (inside or outside the boundary), click OK, say Yes to the warning (YES, THIS COMMAND WILL DELETE ALL OBJECTS OUTSIDE THE BOUNDARY!) ……
Boundary Trim AutoCAD Map 3D toolset
……and, voila, all objects are trimmed outside the boundary.
Now that is awesome!
Stay tuned for the third installment of the “Map 3D Toolset Tools for Regular AutoCAD Objects” series!
The post Map 3D Toolset Tools for Regular AutoCAD Objects [Part Two]: Boundary Trim appeared first on AutoCAD Blog.
zNbdT-BZT5I
View the full article
