Pommer93 Posted May 14, 2019 Posted May 14, 2019 Hi! I made an code that can burst and change txt in my dwg but now i want to change my xref at same time when i but the script in my current drawing, can someone help me please? Here is my code so far. (vl-load-com) (defun C:NYBURSTLSP (/ flag ss1 ss2 ss3 ss4 entities len count ent ent_data ent_name new_style_name otlm) (setq otlm (getvar 'tilemode)) (setvar 'TILEMODE 1) (setq ss1 (ssget "X" '((0 . "INSERT")))) (sssetfirst nil ss1) (C:Burst) (if (setq i -1 ss (ssget "X" '((0 . "MULTILEADER")))) (while (setq ent (ssname ss (setq i (1+ i)))) (and (vlax-method-applicable-p (setq obj (vlax-ename->vla-object ent)) 'Explode) (vla-explode obj)) (entdel ent))) (if (setq ss3 (ssget "X" '((8 . "Annotation")))) (progn (initcommandversion) (command "explode" ss3 ""))) (if (setq ss4 (ssget "X" '((8 . "0")))) (progn (initcommandversion) (command "explode" ss4 ""))) (if (setq ss1 (ssget "X" '((0 . "MTEXT")))) (progn (initcommandversion) (command "explode" ss1 ""))) (command "-STYLE" "Arial Narrow" "Arial Narrow" "0" "1" "0" "n" "n") (setq entities (ssget "X" '((0 . "*TEXT"))) len (sslength entities) count 0) (while (< count len) (setq ent (ssname entities count) ent_data (entget ent) ent_name (cdr (assoc 7 ent_data)) );setq (setq new_style_name (cons 7 "Arial Narrow")) (setq ent_data (subst new_style_name (assoc 7 ent_data) ent_data)) (entmod ent_data) (setq count (+ count 1)) );while (setq ArialFont (strcat (getenv "systemroot") "\\Fonts\\Arial.ttf")) (and (setq StandardTextSTyle (vla-item (vla-get-textstyles (vla-get-activedocument (vlax-get-acad-object))) "Standard")) (vlax-write-enabled-p StandardTextSTyle) (vlax-property-available-p StandardTextSTyle 'Fontfile) (vlax-put StandardTextSTyle 'Fontfile ArialFont) ) (setvar 'tilemode otlm) (princ) ) Quote
