I am not allowed send a private message.
Briscad finds the proxy objects, will fire up other pc with CIV3D.
There is a "SVY_VEHICLETRACKING_DATA" dictionary in the namedobjdict.
This code will get rid of it (tested on BricsCAD). You may have to open the files in 'Vanilla' AutoCAD to be able to batch process them without popup messages. Or use the code before saving to the 2013 format. Note: use at your own risk!
(defun c:Del_VTD ( / enm)
  (if (setq enm (cdr (assoc -1 (dictsearch (namedobjdict) "SVY_VEHICLETRACKING_DATA"))))
      (vla-delete (vlax-ename->vla-object enm)) ; Entdel does not work (BricsCAD).
      (if (vlax-erased-p enm)
        (princ "\nSVY_VEHICLETRACKING_DATA dictionary has been erased ")
Edited by Roy_043
Added feedback to code
  • Thanks 1
Thank Roy,
This works perfectly,  appreciate the help.
On 5/22/2019 at 10:41 AM, dweafer said:
Hi all,
We are having serious issues with AutoCad 2019 in our office.  I have decided to switch back to 2016.  Our IT had advised that all drawings were to be saved as a 2018 version.
I have saved my 200+ drawings back to 2013 version.
Switching to a four year old version seems drastic.  Gotta ask what was the issue with AutoCAD 2019?
