samifox Posted May 23, 2019 Posted May 23, 2019 hi I've customized AutoCAD for each discipline I use by creating a different profile for each. in order to use that specific profiled AutoCAD i use a shortcut at my desktop with some switches in the target property. that practice makes the double-clicking to open the default AutoCAD. how can I double click a dwg and have a popup appear that asks me which profiled AutoCAD i want to use opening this dwg? Thanks Shay Quote
rkmcswain Posted May 23, 2019 Posted May 23, 2019 You're going to need a 3rd party application to which you associate DWG files. In the meantime, you an drag+drop the DWG file onto the shortcut, or open the application first using the desired shortcut, then drag+drop the DWG file onto the title bar or command line. Quote
BIGAL Posted May 24, 2019 Posted May 24, 2019 If you save, say to users1 a profile name you can check it. Users!-5 are variables that you can save stuff into Userr1-5 is reals and userI1-5 are integers (setvar "useri1" 1) . Using xdata would be better to save profile name. Look at this https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/display-current-profile/td-p/847344 Quote
