samifox Posted May 23, 2019 Share Posted May 23, 2019 hi I've customized AutoCAD for each discipline I use by creating a different profile for each. in order to use that specific profiled AutoCAD i use a shortcut at my desktop with some switches in the target property. that practice makes the double-clicking to open the default AutoCAD. how can I double click a dwg and have a popup appear that asks me which profiled AutoCAD i want to use opening this dwg? Thanks Shay Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted May 23, 2019 Share Posted May 23, 2019 You're going to need a 3rd party application to which you associate DWG files. In the meantime, you an drag+drop the DWG file onto the shortcut, or open the application first using the desired shortcut, then drag+drop the DWG file onto the title bar or command line. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 24, 2019 Share Posted May 24, 2019 If you save, say to users1 a profile name you can check it. Users!-5 are variables that you can save stuff into Userr1-5 is reals and userI1-5 are integers (setvar "useri1" 1) . Using xdata would be better to save profile name. Look at this https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/display-current-profile/td-p/847344 Quote Link to comment Share on other sites More sharing options...
