How can I make this insert at the right scale?
Well i really hope thats the case and i havent wasted your time.
  • Replies 51
  • Lee Mac
    24
  • BLOACH85
    21
  • fixo
    7
I found this @
http://www.cadtutor.net/forum/archive/index.php/t-6684.html
but it scales a block not a vla object would it work?
;; Match Block
;; Matches properties from doner block to selected blocks
;; Properties include x,y,z scale factor, rotation, color, layer,
;; linetype, and linetypescale
(defun c:mb (/ srcblk ensel srcobj prop blkobj blk color linetype
rotation x-scale y-scale z-scale layer linetypescale lineweight plotstylename
(if (setq srcblk (car (entsel "\nSelect source block: ")))
(setq srcobj (vlax-ename->vla-object srcblk)
x-scale (vla-get-xscalefactor srcobj)
y-scale (vla-get-yscalefactor srcobj)
z-scale (vla-get-zscalefactor srcobj)
rotation (vla-get-rotation srcobj)
color (vla-get-color srcobj)
linetype (vla-get-linetype srcobj)
layer (vla-get-layer srcobj)
linetypescale (vla-get-linetypescale srcobj)
lineweight (vla-get-lineweight srcobj)
(while (progn
(prompt "\nSelect destination block: ")
(setq blk (ssget "+.:E:S"))
(setq blkobj (vlax-ename->vla-object (ssname blk 0)))
(prompt "\*** Got one. ***")
(vla-put-xscalefactor blkobj x-scale)
(vla-put-yscalefactor blkobj y-scale)
(vla-put-zscalefactor blkobj z-scale)
(vla-put-rotation blkobj rotation)
(vla-put-Color blkobj color)
(vla-put-Linetype blkobj linetype)
(vla-put-layer blkobj layer)
(vla-put-linetypescale blkobj linetypescale)
(vla-put-lineweight blkobj lineweight)
(prompt "\*** Match Block Loaded, Enter MB to run. ***")
I use Annotative object scale on every drawing. so if i have a current scale set why could we not use
(setq tb(vlax-ename->vla-object(car(entsel))))
(vla-get-XEffectiveScaleFactor 'tb)
(vla-get-XScaleFactor 'tb)
(vla-set-XEffectiveScaleFactor 'tb)
(vla-set-XScaleFactor 'tb)
ok so apparently the vla-set commands on my last post do not exists
so....back to step 1 i guess
vla-set-...xxx does not exist I don't think,
the opposite of vla-get is vla-put
So maybe something like:
vla-put-XScaleFactor...
If you need to scale this table uniformly try the following one:
(setq pt (getpoint "\nSpecify base point: ")
       dblscale (getreal "\nSpecify scale factor: ")
(vla-scaleentity tb (vlax-3d-point pt) dblscale)
~'J'~
Ok, buddy
Type (vl-load-com) in the command line then
Open VLIDE
and then
type vla-put-xscalefactor there then select it and press "Apropos" button
(red "(A)" in main menu) and you will be happy
From help:
Specifies the X scale factor for the block or external reference (xref).
~'J'~
You're quite welcome
Hint
I think your sharp brain is ready to learn C++/ObjectARX
at the same time, trust me :)
Try start
~'J'~
Thank you for your kind words Fixo, I just don't want to confuse myself :)
Do you think C++/Object ARX is the way to go, or should I perhaps try to learn Java?
I don't know, sorry
Ask about the big brothers from this forum,
say TT or MP or LE :)
~'J'~
