Burrr Posted May 27, 2019 Posted May 27, 2019 Hey guys, I have a task to do with lisp. So I want to choose 3 points (getpoint) in autoCAD, connect them with a closed line and define the points with the pointstyle 33 (pdmode). My "coding" so far: ( defun c:punktverb () ; ; LISP fragt nacheinander drei Punkte ab und stellt sie als geschlossenen Linienzug dar mit dem Punkstil 33 (alert "Geben Sie drei Punkte ein") ; Eingabe von Punkten (setq p1 (getpoint "Eingabe von Punkt 1")) (setq p2 (getpoint "Eingabe von Punkt 2")) (setq p3 (getpoint "Eingabe von Punkt 3")) (setq x1 (nth 0 p1) y1 (nth 0 p1) x2 (nth 0 p2) y2 (nth 0 p2) x3 (nth 0 p3) y3 (nth 0 p3)) (command "_line" (list x1 y1) (list x2 y2) (list x3 y3)"") So my problem is, after I choosed the three points in CAD, I get a line, but the line is straight and dont lies on the points. In addition the line isnt a straight line, its splitted in two. I appreciate every help Quote
Tharwat Posted May 27, 2019 Posted May 27, 2019 Hi, Simple codes for you to learn from. (defun c:punktverb ( / p1 p2 p3) (and (setq p1 (getpoint "Eingabe von Punkt 1")) (setq p2 (getpoint "Eingabe von Punkt 2")) (setq p3 (getpoint "Eingabe von Punkt 3")) (entmake (list '(0 . "LINE") (cons 10 p1) (cons 11 p2))) (entmake (list '(0 . "LINE") (cons 10 p2) (cons 11 p3))) (entmake (list '(0 . "LINE") (cons 10 p3) (cons 11 p1))) ) (princ) ) Quote
dlanorh Posted May 27, 2019 Posted May 27, 2019 (edited) Just for fun ; LISP fragt nacheinander drei Punkte ab und stellt sie als geschlossenen Linienzug dar mit dem Punkstil 33 (defun c:punktverb ( / mygetpoint lst p_lst cnt) (alert "Geben Sie drei Punkte ein") (defun mygetpoint (p_txt / pt ) (setq pt (getpoint (strcat "\nEingabe von Punkt " p_txt " : "))) (entmake (list (cons 0 "POINT") (cons 10 pt))) pt );end_defun (setvar 'pdmode 33) (setq lst (list "1" "2" "3")) (mapcar '(lambda (x) (setq p_lst (cons (mygetpoint x) p_lst))) lst) (setq p_lst (reverse (cons (last p_lst) p_lst)) cnt 0 );end_setq (repeat (1- (length p_lst)) (entmake (list '(0 . "LINE") (cons 10 (nth cnt p_lst)) (cons 11 (nth (1+ cnt) p_lst)))) (setq cnt (1+ cnt)) );end_repeat (princ) );end_defun Edited May 27, 2019 by dlanorh Quote
BIGAL Posted May 28, 2019 Posted May 28, 2019 My $0.05 (command "line" p1 p2 p3 p1 "") or (command "pline" p1 p2 p3 "c") Quote
