Import .las files into Autocad C3D
Shablab
I am having a hard time converting a .las file to create a surface in C3D & I was wondering if anyone had familiarity with this. I brought the .las file into ArcGIS and created a Raster then extracted contours from the raster but this did not work out the way I hoped. I see that C3D is able to open .rcp & .rcs files. I was wondering if this would be the route I need to take and how do I convert into either of those formats?
One work around I've used is using Autodesk Recap to convert the files but my issues then stem from the surface thinking the trees are ground points.
Edited by Shablab
