ThatGermanFool
Using cutlclip and pasteclip for block definition
ThatGermanFool
Hi guys,
I'm wondering whether it is possible to use cutlclip and pasteclip for block Definition in Lisp.
Normally, I would use an empty block, some attdefs, an endblk and entmake the objects I got with ssget in between. Afterwards, I'd delete the whole ssget selection set and insert the block instead.
;; create empty block
(entmake (list
			(cons 0 "INSERT")
			(cons 2 blname)
			(cons 70 66)
			(cons 10 pIns)
) ;; end entmake
[ENTMAKE OBJECTS HERE]
(entmake (list (cons 0 "ATTDEF")[...]))
;; set end of block
(entmake (list (cons 0 "ENDBLK")))
As entmaking inserts or polylines etc. is some work, I'd like to know if and how I  could use pasteclip instead.
Hope, my question is not that confusing.
Cheers, Seb
Share this post
Link to post
ronjonp
Perhaps try using THIS.
Share this post
Link to post
ThatGermanFool
Hi ronjonp, thank you for your answer, but the thread seems to be inaccessible to me :(
"The topic or board you are looking for appears to be either missing or off limits to you."
Share this post
Link to post
ronjonp
Attached is the code from TheSwamp. You should create an account there though ... lots of smart peeps there :).
EntMaker CAB 05- MakeEntmake.lsp
Edited by ronjonp
  • Thanks 1
Share this post
Link to post
ThatGermanFool
Thank you! It is not what I needed (I need to process nested blocks as well).
But I'll consider signing up for the Swamp :)
Share this post
Link to post
ronjonp
Do you have to use entmake? Here is a simple example to add selected objects to a block using vla.
(defun c:foo (/ a b s)
  (setq a (vla-get-activedocument (vlax-get-acad-object)))
  (setq b (vla-add (vla-get-blocks a) (vlax-3d-point '(0. 0. 0.)) "MyNewBlock"))
  ;; (vlax-for x b (vla-delete x))
  (and (setq s (ssget))
       (setq s (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))))
       (vlax-invoke a 'copyobjects s b nil)
(vl-load-com)
Edited by ronjonp
  • Thanks 1
Share this post
Link to post
ThatGermanFool
(vl-load-com)
That looks like it could work. Thank you for pointing that out! I always forget that the visual Lisp functions are pretty powerful. Will try it later and report back to you :)
Share this post
Link to post
ThatGermanFool
This is what I needed.
I came up with a combination of Copybase and Pasteblock and then modifying attributes with visual Lisp. Thanks for the hint tho.
(vl-load-com)
;; prompt block name
(setq blname (getstring "SAY MY NAME!\n"))
;; prompt remark (optional)
(setq remark (getstring "Who is the one who knocks? (optional)\n"))
;; prompt objects to include
(setq blockSelection (ssget))
;; prompt insertion point
(setq pIns (getpoint "What's the point?\n"))
;; copy to block
(command "_.COPYBASE" pIns blockSelection "")
(command "_.PASTEBLOCK" pIns)
;; change name
(vla-put-name (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 (entget (entlast))))) blname)
;; add attributes
(setq item (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) blname))
;; Name
(vla-addattribute
   item
   400
   (+ acattributemodelockposition acAttributeModeInvisible)
   "name"
   (vlax-3D-point 0 0 0)
   "name"
   blname
;; Remark
(vla-addattribute
   item
   400
   "remark"
   "remark"
   remark
;; update block with attribute
(command "_.attsync" "_N" blname)
;; erase selection
(command "_erase" blockSelection "")
Share this post
Link to post
ronjonp
Glad you got it sorted!
Share this post
Link to post
