TOMJETLAND Posted June 8, 2019 Posted June 8, 2019 Hi everyone, Apologies if this is a daft question! Can anyone point me in the direction of some free trees blocks? I need them for drawing street scene elevations and was wondering how I`m going to get my hands on some blocks? I need a block where I can edit the trunk , spread and height values. Any help/discussion would be useful. Thanks. Quote
BIGAL Posted June 9, 2019 Posted June 9, 2019 (edited) What did google reveal for trees dynamic block. Given you have LT. Edited June 9, 2019 by BIGAL Quote
ammobake Posted June 10, 2019 Posted June 10, 2019 personally I haven't seen a dynamic tree block before. There are some interesting things on the autodesk app store for trees though. One will randomize tree size using a recursive algorithm. The app is free. https://apps.autodesk.com/ACD/en/Detail/Index?id=7862815101732893124&appLang=en&os=Win32_64 ChriS Quote
BIGAL Posted June 13, 2019 Posted June 13, 2019 In civ3d you survey trees so you pick up trunk and spread as two values so its obvious you take advantage of a dynamic block that reads the description of a point and adjusts trunk size and spread accordingly. 234,x,xy,z, tr3-S5 so this is a point that has a trunk of 0.3 m diameter and a spread of 5m so the block is drawn correctly. If any one wants the code post a request. Quote
eldon Posted June 13, 2019 Posted June 13, 2019 For a street scene elevation, I would have thought that a tree in elevation would be more useful than a tree in plan, but that would have to have three inputs, trunk diameter, spread and height. I haven't seen any of these, but I have waded through tree elevation blocks available free on various websites, until I found something that could be adapted. Quote
BIGAL Posted June 14, 2019 Posted June 14, 2019 Your right Eldon need 3d trees. A simple 3d tree is take a 2d tree flip vertical then copy and rotate around base point you end up with something at 1st glance looks 3d Quote
