How to create a tag with several types?
Siberian
I'm trying to modify a tag so that it can have two types where the difference between them simply is the label text size. I'm just not able to figure out how to do this. I can solve it by just creating a separate tag all together, but I would still like to know how it can be done (if it can). Any ideas?
You'll have to use Yes/No parameters and associate them with the Visibility parameter for each Label, then use Types to distinguish between each one.
-TZ
That worked nicely. Thanks!
