I'm wanting to create a way to quickly change the layers of a CADworx object.
This is what I have so far but its not working like I want. The problem is no matter how many objects I select, it only changes the first then stops working completely. If I try to run it again and select another object it wont do anything. I need to be able to select objects manually.
Can someone point me in the right direction?
(defun C:ttt ()
   (setq STL_SS nil)
   (graphscr)
   (setq STL_SS (ssget '((0 . "LINE")(8 . "CL_Steel"))));;;FIND ALL THE LINES ON LAYER CL-STEEL
   (setq CL_CNT 0)
   (if (/= STL_SS nil)
      (repeat (sslength STL_SS)
         (setq STL_NAME (ssname STL_SS CL_CNT))
         (setvar "pickstyle" 0)
            (command "chprop" STL_NAME "" "LA" "BEAM_CL" "")
         (setq CL_CNT (1+ CL_CNT))
      );;;repeat
   );;;if
   (setq STL_SS nil)
   (setq STL_SS (ssget "L" '((0 . "3DSOLID")(8 . "STEEL"))));;;FIND ALL THE SOLIDS ON LAYER STEEL
   (setq CL_CNT 0)
   (if (/= STL_SS nil)
            (command "chprop" STL_NAME "" "LA" "BEAM" "")
      );;;repeat
   );;;if
   (setvar "pickstyle" 1)
Edited by jonathann3891
Hi,
Something like this?
(defun c:test (/ s i n e )
  (if (setq s (ssget '((-4 . "<OR") (-4 . "<AND") (0 . "LINE")(8 . "CL_Steel") (-4 . "AND>")
                                    (-4 . "<AND") (0 . "3DSOLID")(8 . "STEEL") (-4 . "AND>")
                       (-4 . "OR>"))))
    (repeat (setq i (sslength s))
      (setq i (1- i)
            e (entget (ssname s i))
      (entmod (subst (cons 8 (if (= (cdr (assoc 0 e)) "LINE") "BEAM_CL" "BEAM")) (assoc 8 e) e))
Nice Tharwat, just thinking the problem would lend its self to a list  answer,  the only problem is when calling the ssget would require repeated select but if "all" is the suggested option then can use "X"
(defun AH:changelay (lst / s y x e)
(setq y 0)
(repeat (setq x (/ (length lst) 3))
    (if (setq s (ssget "x" (list (cons 0 (nth y lst))(cons 8 (nth (+ y 1) lst)))))
        (setq i (1- i)
        (entmod (subst (cons 8 (nth (+ y 2) lst))(assoc 8 e) e))
      (alert (strcat "layer not found  " (nth (+ y 1) lst)))
    (setq y (+ y 3))
(AH:changelay ( list "line" "Cl_Steel" "BEM_CL" "3DSOLID" "STEEL" "BEAM" "line" "Ex-Serv-Gas" "Gas-Main"))
or
"line" "Cl_Steel" "BEAM_CL"
Could add the "x" as part of the list and check for a user slect.
"line" "Cl_Steel" "BEAM_CL" "x"
"3DSOLID" "STEEL" "BEAM" ""
"line" "Ex-Serv-Gas" "Gas-Main" "X" )
Edited by BIGAL
Tharwat that works perfectly and much simpler.
Thanks!
Thanks!
You're welcome anytime. :)
Thank you @BIGAL. :)
