sublimation
Issues with Storing/Retrieving FILLETRAD
sublimation
I can't figure out why the setvar and getvar work when I preselect my entities but not when I select them individually.  When I select the lines manually, my code extends the lines but with the original radius.
; EXTENDS 2 LINES TO COMMON POINT
(defun C:ETP (/ xFillRad xArrEnt xCMD)
	(setq xCMD (getvar "CMDECHO"))
	(setvar "CMDECHO" 0)
	(setq xFillRad (getvar "FILLETRAD"))
	(setvar "FILLETRAD" 0.0)
  	(IF (NOT (setq xArrEnt (SSGET "_I")))
		(COMMAND "FILLET" "T" "T")
		(COMMAND "FILLET" "T" "T" (ssname xArrEnt 0) (ssname xArrEnt 1))
	(setvar "FILLETRAD" xFillRad)
	(setvar "CMDECHO" xCMD)
Share this post
Link to post
Roy_043
When the _Fillet comand prompts you to select entities, the code has completely finished, and therefore the variables have already been reset.
Try changing:
To:
(COMMAND "FILLET" "T" "T" pause pause)
You should also verify if the cmdecho should actually be ON for that part of the code.
  • Thanks 1
Share this post
Link to post
sublimation
Dude!  That solved it and totally makes sense!  Thank you very much!
Share this post
Link to post
tombu
With Shift key pressed while selecting the second segment with the FILLET command 0 radius will always be used no matter what FILLETRAD is set to.  Easy peasy.
Share this post
Link to post
sublimation
Handy tip! Thanks!
Share this post
Link to post
