Sorry English is not good
Hello all the members
Problem in lisp ... please help
I have a lisp  that makes me wrong  at IntersectWith
"Command: ; error: ActiveX Server returned an error: Parameter not optional"
What's the reason
Please treatment the problem please
this lisp
(defun c:lpp (/ entity pt acExtendBoth ANG ENT1 ENT2 HT LEV LEVI LEVIM LEVIP LW NPTYY NPTYYM NPTYYP P PLL PP PP1 PTPMIN1 X19 Y19 YI YIP acExtendNone FEAT FEATUR FILE LST LW P XI)
  (COMMAND "PDMODE" 35)
  (COMMAND "PDSIZE" 0.2)
 (setq lw (CAR(entsel "\nSelect the PROFILE LWPOLYLINE")))
 (setq lev (* 10 27.3))
 (setq pll (mapcar '(lambda ( p ) (trans (list (car p) (cadr p) (cdr (assoc 38 (entget lw)))) lw 0)) (mapcar 'cdr (vl-remove-if  '(lambda ( x ) (/= (car x) 10)) (entget lw)))))
 (setq x19(car(car pll)))
 (setq y19(cadr(car pll)))
(while
(setq pp (getpoint "\nSelect point on PROFILE : "))
(setq xi (- (car PP) x19))
(command "XLINE" "V" PP "")
            (setq ent1 (vlax-ename->vla-object lw))
                (setq ent2 (vlax-ename->vla-object (entlast)))
                (setq PP1 (vlax-safearray->list (vlax-variant-value (vla-IntersectWith ent1 ent2 acExtendNone))))
                (entdel (entlast))
            (setq yi (- (cadr PP1) y19))
                (setq levi(/ (+ lev yi) 10))
                (setq ang (angle '(0.0 0.0 0.0) (vlax-curve-getfirstderiv lw (vlax-curve-getparamatpoint lw PP1))))
                (entmakex (list '(0 . "LINE")
(cons 10 (setq pt(polar PP1 (+ ang (/ pi 2.)) 0.3)))
(cons 11 (polar PP1 (- ang (/ pi 2.)) 0.3))
         (setq NPTYY (rtos levi))
    (command "text" "j" "ML" pt 0.3 90 NPTYY)
    (command "._Change" (entlast) "" "p" "color" "80" "")
(setq yip (- (cadr pp) y19))
(setq levip(/ (+ lev yip) 10))
(setq NPTYYp (rtos levip))
        (COMMAND "_.POINT" pp "")
    (command "text" "j" "ML" pp 0.3 90 NPTYYp)
        (setq ptpmin1 (list (car pp) (+ (cadr pp) (/ (- (cadr pt) (cadr pp)) 2)) 0))
        (setq levim(- levi levip))
        (setq NPTYYm (rtos levim))
        (command "text" "j" "ML" ptpmin1 0.3 90 NPTYYm)
            (setq FEAT(LIST xi levi levip levim))
            (setq FEATUR(APPEND FEAT FEATUR))
) ;_ while
(setq lst  FEATUR)
  (if (setq    file (open (strcat (getvar 'dwgprefix)
                   "Lwpolyline Vertex List.csv"
               "w"
      (write-line (strcat "Distance" "," "LEVEL_NGL" "," "LEVEL_Manhal" "," "The difference") file)
          (repeat (/ (length lst) 4)
       (write-line
        (strcat    (rtos (car lst))
            (rtos (cadr lst))
            (rtos (caddr lst))
            (rtos (cadddr lst))
        file
          (setq lst (cddddr lst))
      (close file)
      (alert "\nVertex Points exported to csv file.")
      (alert (strcat "File saved in - "
             (getvar 'dwgprefix)
    (alert "\nCSV file Currenty running, Close it first.")
) ;_ defun
profile lisp.dwg
Edited by hosneyalaa
Try to add to the lisp
(vl-load-com)
ERROR   :  acExtendBoth and acExtendNone are AutoCAD constants. You are defining them as local variables in the lisp so they are set to nil. This gives the error.
Solution :  Remove them from the local variable list.
Edited by dlanorh
  • Thanks 1
thank you
Of this was the problem
