svorgodne
lastprompt
svorgodne
Hello everyone,
What is the exact use for the system variable "Lastprompt"?
I want preciselly its value through autolisp to copy/paste automatically as text somewhere else.
Nothing more, nothing less.
Any ideas?
Thanks in advance
Sergio
Share this post
Link to post
dlanorh
lastprompt : This string is identical to the last line seen at the Command prompt and includes any user input.
Test routine
(defun c:testLP ( / tmp lp)
	(setq tmp (getpoint "\nSelect Point : ")
		  lp (getvar 'lastprompt)
    (princ lp)
This doesn't return "Select Point :  (0.0 0.0 0.0)" but  "command c:testLP" as this was the last thing run on the command line.
If you enter (princ (getvar 'lastprompt)) at the "Command:" prompt it returns  "Command: (princ (getvar 'lastprompt))"
Edited by dlanorh
Share this post
Link to post
tombu
It's not really useful in lisp, but you can display the value you're looking for in the Ribbon using DIESEL for Display Name like :
$(getvar,lastprompt)
Share this post
Link to post
