therock005 Posted July 10, 2019 Posted July 10, 2019 I want to create a template text entry which i import in each new drawing, where somewhere inside theres an area filed entry information. For example "Polygon area is #areafield sq.m." And the only thing i have to do each time i import is choose the polygon. So far if i do it in one drawing and select the object that i want, when i insert in new drawing its information appears as unkown since it doesn not know where the object is. Is there an easier way to do this, or do i have to do the mtext edit, highlight the field entry and then set it from scratch. Its not just one mtext that i want to do this with, otherwise i would not mind. Quote
BIGAL Posted July 12, 2019 Posted July 12, 2019 (edited) There is numerous label area lisps out there a quick search should find what you want some are metric others imperial but easy to change the field definition. http://www.lee-mac.com/areastofield.html Edited July 12, 2019 by BIGAL Quote
