i_try Posted July 11, 2019 Share Posted July 11, 2019 (edited) I have a dynamic block for section cuts and I need the interior line to adapt stretch to to be trimed by the contour when I turn it. this is the block when I select it for the time being. My current work around is that I have the line constrained with a stretch that I manually need to bring to the edge. I also have a visibility state so I can pass from section with page or same page is there a way to place the same attribute (Not two as I currently have) in two location depending on the state? Is there someone who knows how to make this work? with just the flip and the turn. I also have a visibility state so I can pass from section with page or same page is there a way to place the same attribute in two location depending on the state? thanks Edited July 11, 2019 by i_try Quote Link to comment Share on other sites More sharing options...
