Andyn
Plotting lighter
Andyn
When plotting some lines are plotting very light. On the preview everything looks good. Thanks
Share this post
Link to post
SLW210
A little more information would help.
What are you plotting to?
A dwg and some screen shots might help.
Generally if the preview is correct, the issue is in the plotter settings.
  • Thanks 1
Share this post
Link to post
CyberAngel
Are you using the "plot object lineweights" and/or "plot with plot styles" toggles in the Plot|Plot Options pane? Does the issue occur with certain layers or certain objects? Are you overriding the Lineweight property on any objects? What Lineweights are you assigning to your layers? What Lineweights are assigned to the pens in your Color Table (assuming you're not using a Style Table)?
As SLW210 says, more information would help. Plotting is one of the most complex operations in AutoCAD.
  • Thanks 1
Share this post
Link to post
Andyn
It is really complex for me😁
Tried both ways with plot object lineweights &plot styles and without. Nope it ocurrs with all layers. I'm using  lineweight 0.00
Share this post
Link to post
BIGAL
If your using a CTB plot style you can customise and make your own setting a pen color line thickness. If you use the default ACAD.ctb what do you get.
Share this post
Link to post
