Alan_KD
XREF layer
Alan_KD
Hello everyone,
I have been developing some routines for the pas 6 months, so my knowledge is not very high. Normally I manage to find answers online, thanks to all of you who share their knowledge, it's so helpful.
I am writing a routine which would:
Compare the XREF name on the drawing and the XREF 'real' file name and match them (on the drawing) if different.
After the code checks if the XREF name matches a specific formatting and if it does creates a layer based on it (if the layer does not already exist).
The final step is to change the XREF layer to that one, and here is where I am getting an error. I tried with different ways to do this and always got an error.
I guess I could try to get this done without using vl code but this is really puzzling me and I would like to know why is actually not working, I dont see where the code could have gone wrong.
The example names of my XREFs: which are used to compare with the wcmatch "*_*_*_*"
XREF_TGLMTE_PRO_INTER_BASSINS_01
XREF_TGLMTE_PRO_INTER_RESEAUX_HS_2025_01
XREF_TGLMTE_PRO_TRC_V5_IND_D
I used different lines of code to try to achieve this, as you can see on my commented lines on the code.
I am currently using a (vlax-put-property it2 'layer strcalq) inside a vlax-for getting the following error:
Quote
Analyse rétrospective:
[0.57] (VL-BT)
[1.53] (ABD:ERROR "Le serveur ActiveX a renvoyé l'erreur: nom inconnu: LAYER")
[2.48] (_call-err-hook #<SUBR @0000029632c73c78 ABD:ERROR> "Le serveur ActiveX a renvoyé l'erreur: nom inconnu: LAYER")
[3.42] (sys-error "Le serveur ActiveX a renvoyé l'erreur: nom inconnu: LAYER")
:ERROR-BREAK.37 nil
[4.34] (intelligent-invoke #<VLA-OBJECT IAcadBlock 0000029ec1c94378> LAYER 4 "SF-XREF_BATI_FOSSE")
[5.26] (vlax-put-property #<VLA-OBJECT IAcadBlock 0000029ec1c94378> LAYER "SF-XREF_BATI_FOSSE")
[6.19] (C:XRCALQUE)
[7.15] (#<SUBR @0000029632c73f20 -rts_top->)
[8.12] (#<SUBR @000002962b338700 veval-str-body> "(C:XRCALQUE)" T #<FILE internal>)
:CALLBACK-ENTRY.6 (:CALLBACK-ENTRY)
:ARQ-SUBR-CALLBACK.3 (nil 0)
(defun c:xrcalque (/ AcadObj AcadAct LyAct it2 xrobjectname strcalq)
(vl-load-com)
(setq *error* ABD:Error)
(setq AcadObj (vlax-get-Acad-Object))
(setq AcadAct (vla-get-ActiveDocument AcadObj))
(setq LyAct (vla-get-layers AcadAct)) ;get layers from Active document
(xrn AcadObj AcadAct); runs the subroutine to change XREF name on drawing to match XREF file name
(vlax-for it2 (vla-get-blocks AcadAct)
    (setq ind1 3)
    (setq ind2 0)
    (setq ind3 0)
    (if (= (vla-get-isxref it2) :vlax-true)
            (setq xrobjectname (vl-filename-base (vla-get-name it2)))
            (if (wcmatch xrobjectname "*_*_*_*");
                        (repeat ind1
                            (setq ind3 (+ ind2 1))
                            (setq ind2 (vl-string-position (ascii "_") xrobjectname ind3));gets firs position of "_" character
                    (print xrobjectname)
                    (setq ind2 (+ ind2 2))
                    (print ind2) ; ind2 is the position of the ind1 "_" element (3rd) to count from there to have the layer name
                    (setq ind4 (vl-string-position (ascii "_") xrobjectname nil T)); last "_" position
                    (setq ind5 (vl-string-position (ascii "-") xrobjectname nil T)); last "-" position
                    (if (> ind4 ind5)(setq indlst ind4)(setq indlst ind5)) ;check which one is bigger
                    (setq indlst (+ 1 indlst))
                        (setq strcalq (strcat "SF-XREF_"(substr xrobjectname ind2 (- indlst ind2))))
                        ;Create layer with string from ind2 position to ind4 or ind5 position (strcalq)
                        (print strcalq)
                    (if (not (tblsearch "LAYER" strcalq));checks non existance of layer
                            (vla-add LyAct strcalq)
                            (print "Layer has been created")
                             ;(vla-put-layer it2 "0")
                            ; (print "this is a test4")
                            (print "layer exists")
                            ;if layer exists put object on layer
                    );if
                    (print strcalq)
                    ;(vla-put-layer xrobjectname strcalq)
                    ;(vla-put-layer (vla-get-name it2) strcalq)
                    ;(vlax-put it2 'Layer "0")
                    ;(vlax-put (vlax-ename->vla-object (vla-get-name it2)) 'Layer "0")
                    (vlax-put-property it2 'layer strcalq);############ ERROR###############
                );progn
                (print "wcmatch xref name not matching")
            );if
        );progn
    );if
    ;(vlax-put (vlax-ename->vla-object xrtemp) 'Layer strcalq)
);vlax for
(print "highly recommended to purge layers") ;add code to purge automatically the layers?
);defun
;;;=======================================  Error function  ++++++++++++++++++++++++++++++++++++++++;;;
(defun ABD:Error (st)
    (if (not (member st (list "Fonction annulée" "quitter / sortir abandon")))
        (vl-bt)
    );if
    ;(princ "Merci d'envoyer vos commentaires ou report d'erreurs à ")
    (princ);clean exit ?
);defun error
;;;=======================================  function xrn  +++++++++++++++++++++++++++++++++++++++++++;;;
(defun xrn (AcadObj AcadAct / item xrobjectnamexrn xrfilenamexrn)
(vlax-for item (vla-get-blocks AcadAct)
    (if (= (vla-get-isxref item) :vlax-true)
            (setq xrobjectnamexrn (vl-filename-base (vla-get-name item)))
            (setq xrfilenamexrn (vl-filename-base (vla-get-path item)))
            (if (/= xrobjectnamexrn xrfilenamexrn)
                    (vla-put-name item xrfilenamexrn)
                    (vla-reload item)
);defun xrn
If someone could explain why this is not working, and please share a way to achieve my goal would be awesome!
Thank you in advance,
Alan
Edited by Alan_KD
Share this post
Link to post
Roy_043
In your code it2 is a block definition. A block definition object does not have a layer property.
So:
Will fail.
You need to change the layer of the block references.
Share this post
Link to post
Emmanuel Delay
So:
Will fail.
Oh yes.
In that case, this works
  (setq xrf (ssget "_X" (list (cons 0 "INSERT") (cons 2 xrobjectname) )))
  (vlax-put-property (vlax-ename->vla-object (ssname xrf 0)) 'layer strcalq);
Edited by Emmanuel Delay
Share this post
Link to post
