Guest Posted July 19, 2019 Share Posted July 19, 2019 Can we Encoding to ANSI the translate text ; I check the language settings in windows and i canot see a problem. The only think i notice is when i inport a text from txt file in mtext editor AND THE TEXT IS UTF-8 I CANT RED THE TEXT. IF THE TEXT IS ANSI I HAVE NO PROBLEM Quote Link to comment Share on other sites More sharing options...
Steven P Posted July 19, 2019 Share Posted July 19, 2019 I was just thinking the same, is it the routine or the text characters? Quote Link to comment Share on other sites More sharing options...
Steven P Posted July 19, 2019 Share Posted July 19, 2019 I put your text in and tried it - seams to work for me as it is (defun c:multipletxtreplace( / echo_old replaceletter acount) (setq cmdecho_old (getvar "cmdecho")) (setvar "cmdecho" 0) (setq replaceletters (list '("A" "Á") '("B" "Â") '("C" "×") '("D" "Ä") '("E" "Å") '("F" "Ö") '("G" "Ã") '("H" "Ç") '("I" "É") '("K" "Ê") '("L" "Ë") '("M" "Ì") '("N" "Í") '("O" "Ï") '("P" "Ð") '("Q" "È") '("R" "Ñ") '("S" "Ó") '("T" "Ô") '("U" "Õ") '("W" "Ù") '("X" "Î") '("Y" "Ø") '("Z" "Æ") )) (setq account 0) (repeat (length replaceletters) (FindReplaceAll (nth 0 (nth account replaceletters)) (nth 1 (nth account replaceletters)) ) (setq account (+ 1 account)) ) (setvar "cmdecho" cmdecho_old) (princ) ) (defun c:txtfindreplace (/ f00 e) (defun f00 (string) (vl-string-translate "ABCDEFGHIKLMNOPQRSTUWXYZ" "ÁÂ×ÄÅÖÃÇÉÊËÌÍÏÐÈÑÓÔÕÙÎØÆ" string) ) (if (and (setq e (car (entsel "\Pick text: "))) (setq e (vlax-ename->vla-object e)) (vlax-property-available-p e 'textstring) ) (vla-put-textstring e (f00 (vla-get-textstring e))) ) (princ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; FindReplaceAll - Changes Text, Mtext, Dimensions and Attribute Block entities ; that have a Find$ string with a Replace$ string. ; Arguments: 2 ; Find$ = Phrase string to find ; Replace$ = Phrase to replace it with ; Syntax: (FindReplaceAll "old string" "new string") ; Returns: Updates Text, Mtext, Dimension and Attribute Block entities ; It is Case sensitive ;------------------------------------------------------------------------------- (defun FindReplaceAll (Find$ Replace$ / BlkEntList@ BlkEntName^ BlkEntType$ Cnt# DimEntList@ DimEntName^ DimEntType$ EntList@ EntName^ EntType$ FindReplace: Mid$ Mid2$ NewText$ Num# Replace$ SS& Text$) ;----------------------------------------------------------------------------- ; FindReplace: - Returns Str$ with Find$ changed to Replace$ ; Arguments: 3 ; Str$ = Text string ; Find$ = Phrase string to find ; Replace$ = Phrase to replace Find$ with ; Returns: Returns Str$ with Find$ changed to Replace$ ;----------------------------------------------------------------------------- (defun FindReplace: (Str$ Find$ Replace$ / Cnt# FindLen# Loop Mid$ NewStr$ ReplaceLen#) (setq Loop t Cnt# 1 NewStr$ Str$ FindLen# (strlen Find$) ReplaceLen# (strlen Replace$)) (while Loop (setq Mid$ (substr NewStr$ Cnt# FindLen#)) (if (= Mid$ Find$) (setq NewStr$ (strcat (substr NewStr$ 1 (1- Cnt#)) Replace$ (substr NewStr$ (+ Cnt# FindLen#))) Cnt# (+ Cnt# ReplaceLen#) );setq (setq Cnt# (1+ Cnt#)) );if (if (= Mid$ "") (setq Loop nil)) );while NewStr$ );defun FindReplace: ;----------------------------------------------------------------------------- ; Start of Main function ;----------------------------------------------------------------------------- (if (and (= (type Find$) 'STR)(= (type Replace$) 'STR)(/= Find$ "")) (progn (if (setq SS& (ssget "x" (list '(-4 . "<AND")'(-4 . "<OR")'(0 . "TEXT")'(0 . "MTEXT")'(0 . "DIMENSION")'(0 . "INSERT")'(-4 . "OR>")(cons 410 (getvar "CTAB"))'(-4 . "AND>")))) (progn (command "UNDO" "BEGIN") (setq Cnt# 0) (repeat (sslength SS&) (setq EntName^ (ssname SS& Cnt#) EntList@ (entget EntName^) EntType$ (cdr (assoc 0 EntList@)) Text$ (cdr (assoc 1 EntList@)) );setq (if (= EntType$ "INSERT") (if (assoc 66 EntList@) (progn (while (/= (cdr (assoc 0 EntList@)) "SEQEND") (setq EntList@ (entget EntName^)) (if (= (cdr (assoc 0 EntList@)) "ATTRIB") (progn (setq Text$ (cdr (assoc 1 EntList@))) (if (wcmatch Text$ (strcat "*" Find$ "*")) (progn (setq ReplaceWith$ (FindReplace: Text$ Find$ Replace$)) (entmod (subst (cons 1 ReplaceWith$) (assoc 1 EntList@) EntList@)) (entupd EntName^) );progn );if );progn );if (setq EntName^ (entnext EntName^)) );while );progn );if (if (wcmatch Text$ (strcat "*" Find$ "*")) (progn (setq ReplaceWith$ (FindReplace: Text$ Find$ Replace$)) (entmod (subst (cons 1 ReplaceWith$) (assoc 1 EntList@) EntList@)) (entupd EntName^) );progn );if );if (setq Cnt# (1+ Cnt#)) );repeat (command "UNDO" "END") );progn );if );progn );if (princ) );defun FindReplaceAll ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Quote Link to comment Share on other sites More sharing options...
Guest Posted July 19, 2019 Share Posted July 19, 2019 IS ANY WAY TO FIX THIS UNICODE ERROR ? IS ANY SETTINGS IN AUTOCAD ? Quote Link to comment Share on other sites More sharing options...
Steven P Posted July 19, 2019 Share Posted July 19, 2019 Its the weekend and AutoCAD is left in the office, howver what happens if you put the unicode code in instead of the letters? For example '("A" "\\U00C0") ? Quote Link to comment Share on other sites More sharing options...
maratovich Posted July 21, 2019 Share Posted July 21, 2019 Batch text replacement for the list of texts Quote Link to comment Share on other sites More sharing options...
Guest Posted July 21, 2019 Share Posted July 21, 2019 Thanks maratovich Quote Link to comment Share on other sites More sharing options...
Guest Posted July 30, 2019 Share Posted July 30, 2019 I replace the leters with unicaode characters but the text didn't change .Can any one tell were is the problem ? (defun c:multipletxtreplace ( / cmdecho_old replaceletters acount) (setq cmdecho_old (getvar "cmdecho")) (setvar "cmdecho" 0) (setq replaceletters (list '("A" "\U+0391") '("B" "\U+0392") '("C" "\U+03A7") '("D" "\U+0394") '("E" "\U+0395") '("F" "\U+03A6") '("G" "\U+0393") '("H" "\U+0397") '("I" "\U+0399") '("K" "\U+039A") '("L" "\U+039B") '("M" "\U+039C") '("N" "\U+039D") '("O" "\U+039F") '("P" "\U+03A0") '("Q" "\U+0398") '("R" "\U+03A1") '("S" "\U+03A3") '("T" "\U+03A4") '("U" "\U+03A5") '("W" "\U+03A9") '("X" "\U+039E") '("Y" "\U+03A8") '("Z" "\U+0396")) ) ;;complete list as required. (setq account 0) (repeat (length replaceletters) (FindReplaceAll (nth 0 (nth account replaceletters)) (nth 1 (nth account replaceletters)) ) (setq account (+ 1 account)) ) (setvar "cmdecho" cmdecho_old) (princ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; FindReplaceAll - Changes Text, Mtext, Dimensions and Attribute Block entities ; that have a Find$ string with a Replace$ string. ; Arguments: 2 ; Find$ = Phrase string to find ; Replace$ = Phrase to replace it with ; Syntax: (FindReplaceAll "old string" "new string") ; Returns: Updates Text, Mtext, Dimension and Attribute Block entities ; It is Case sensitive ;------------------------------------------------------------------------------- (defun FindReplaceAll (Find$ Replace$ / BlkEntList@ BlkEntName^ BlkEntType$ Cnt# DimEntList@ DimEntName^ DimEntType$ EntList@ EntName^ EntType$ FindReplace: Mid$ Mid2$ NewText$ Num# Replace$ SS& Text$) ;----------------------------------------------------------------------------- ; FindReplace: - Returns Str$ with Find$ changed to Replace$ ; Arguments: 3 ; Str$ = Text string ; Find$ = Phrase string to find ; Replace$ = Phrase to replace Find$ with ; Returns: Returns Str$ with Find$ changed to Replace$ ;----------------------------------------------------------------------------- (defun FindReplace: (Str$ Find$ Replace$ / Cnt# FindLen# Loop Mid$ NewStr$ ReplaceLen#) (setq Loop t Cnt# 1 NewStr$ Str$ FindLen# (strlen Find$) ReplaceLen# (strlen Replace$)) (while Loop (setq Mid$ (substr NewStr$ Cnt# FindLen#)) (if (= Mid$ Find$) (setq NewStr$ (strcat (substr NewStr$ 1 (1- Cnt#)) Replace$ (substr NewStr$ (+ Cnt# FindLen#))) Cnt# (+ Cnt# ReplaceLen#) );setq (setq Cnt# (1+ Cnt#)) );if (if (= Mid$ "") (setq Loop nil)) );while NewStr$ );defun FindReplace: ;----------------------------------------------------------------------------- ; Start of Main function ;----------------------------------------------------------------------------- (if (and (= (type Find$) 'STR)(= (type Replace$) 'STR)(/= Find$ "")) (progn (if (setq SS& (ssget "x" (list '(-4 . "<AND")'(-4 . "<OR")'(0 . "TEXT")'(0 . "MTEXT")'(0 . "DIMENSION")'(0 . "INSERT")'(-4 . "OR>")(cons 410 (getvar "CTAB"))'(-4 . "AND>")))) (progn (command "UNDO" "BEGIN") (setq Cnt# 0) (repeat (sslength SS&) (setq EntName^ (ssname SS& Cnt#) EntList@ (entget EntName^) EntType$ (cdr (assoc 0 EntList@)) Text$ (cdr (assoc 1 EntList@)) );setq (if (= EntType$ "INSERT") (if (assoc 66 EntList@) (progn (while (/= (cdr (assoc 0 EntList@)) "SEQEND") (setq EntList@ (entget EntName^)) (if (= (cdr (assoc 0 EntList@)) "ATTRIB") (progn (setq Text$ (cdr (assoc 1 EntList@))) (if (wcmatch Text$ (strcat "*" Find$ "*")) (progn (setq ReplaceWith$ (FindReplace: Text$ Find$ Replace$)) (entmod (subst (cons 1 ReplaceWith$) (assoc 1 EntList@) EntList@)) (entupd EntName^) );progn );if );progn );if (setq EntName^ (entnext EntName^)) );while );progn );if (if (wcmatch Text$ (strcat "*" Find$ "*")) (progn (setq ReplaceWith$ (FindReplace: Text$ Find$ Replace$)) (entmod (subst (cons 1 ReplaceWith$) (assoc 1 EntList@) EntList@)) (entupd EntName^) );progn );if );if (setq Cnt# (1+ Cnt#)) );repeat (command "UNDO" "END") );progn );if );progn );if (princ) );defun FindReplaceAll ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted July 30, 2019 Share Posted July 30, 2019 I find it. i explode the mtext and works. Is it possible to work for mtext? Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2019 Share Posted August 2, 2019 (edited) I fix it . Thanks Edited August 2, 2019 by prodromosm Quote Link to comment Share on other sites More sharing options...
Steven P Posted August 2, 2019 Share Posted August 2, 2019 how did you fix it? Quote Link to comment Share on other sites More sharing options...
bkartal16 Posted August 18, 2020 Share Posted August 18, 2020 On 7/18/2019 at 1:47 PM, Steven P said: This might give you a start, command txtreplace which you could modify to accept multiple inputs and then run the FindReplaceAll function for each letter. Note this is case sensitive. ;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/find-and-replace-text/td-p/5649883 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun c:txtreplace( / old_text new_text) (setq old_text (getstring T "OLD Text to replace (replace in this model/paper space and text case as entered): ")) (setq new_text (getstring T "NEW text to use: ")) (FindReplaceAll old_text new_text) (princ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; FindReplaceAll - Changes Text, Mtext, Dimensions and Attribute Block entities ; that have a Find$ string with a Replace$ string. ; Arguments: 2 ; Find$ = Phrase string to find ; Replace$ = Phrase to replace it with ; Syntax: (FindReplaceAll "old string" "new string") ; Returns: Updates Text, Mtext, Dimension and Attribute Block entities ; It is Case sensitive ;------------------------------------------------------------------------------- (defun FindReplaceAll (Find$ Replace$ / BlkEntList@ BlkEntName^ BlkEntType$ Cnt# DimEntList@ DimEntName^ DimEntType$ EntList@ EntName^ EntType$ FindReplace: Mid$ Mid2$ NewText$ Num# Replace$ SS& Text$) ;----------------------------------------------------------------------------- ; FindReplace: - Returns Str$ with Find$ changed to Replace$ ; Arguments: 3 ; Str$ = Text string ; Find$ = Phrase string to find ; Replace$ = Phrase to replace Find$ with ; Returns: Returns Str$ with Find$ changed to Replace$ ;----------------------------------------------------------------------------- (defun FindReplace: (Str$ Find$ Replace$ / Cnt# FindLen# Loop Mid$ NewStr$ ReplaceLen#) (setq Loop t Cnt# 1 NewStr$ Str$ FindLen# (strlen Find$) ReplaceLen# (strlen Replace$)) (while Loop (setq Mid$ (substr NewStr$ Cnt# FindLen#)) (if (= Mid$ Find$) (setq NewStr$ (strcat (substr NewStr$ 1 (1- Cnt#)) Replace$ (substr NewStr$ (+ Cnt# FindLen#))) Cnt# (+ Cnt# ReplaceLen#) );setq (setq Cnt# (1+ Cnt#)) );if (if (= Mid$ "") (setq Loop nil)) );while NewStr$ );defun FindReplace: ;----------------------------------------------------------------------------- ; Start of Main function ;----------------------------------------------------------------------------- (if (and (= (type Find$) 'STR)(= (type Replace$) 'STR)(/= Find$ "")) (progn (if (setq SS& (ssget "x" (list '(-4 . "<AND")'(-4 . "<OR")'(0 . "TEXT")'(0 . "MTEXT")'(0 . "DIMENSION")'(0 . "INSERT")'(-4 . "OR>")(cons 410 (getvar "CTAB"))'(-4 . "AND>")))) (progn (command "UNDO" "BEGIN") (setq Cnt# 0) (repeat (sslength SS&) (setq EntName^ (ssname SS& Cnt#) EntList@ (entget EntName^) EntType$ (cdr (assoc 0 EntList@)) Text$ (cdr (assoc 1 EntList@)) );setq (if (= EntType$ "INSERT") (if (assoc 66 EntList@) (progn (while (/= (cdr (assoc 0 EntList@)) "SEQEND") (setq EntList@ (entget EntName^)) (if (= (cdr (assoc 0 EntList@)) "ATTRIB") (progn (setq Text$ (cdr (assoc 1 EntList@))) (if (wcmatch Text$ (strcat "*" Find$ "*")) (progn (setq ReplaceWith$ (FindReplace: Text$ Find$ Replace$)) (entmod (subst (cons 1 ReplaceWith$) (assoc 1 EntList@) EntList@)) (entupd EntName^) );progn );if );progn );if (setq EntName^ (entnext EntName^)) );while );progn );if (if (wcmatch Text$ (strcat "*" Find$ "*")) (progn (setq ReplaceWith$ (FindReplace: Text$ Find$ Replace$)) (entmod (subst (cons 1 ReplaceWith$) (assoc 1 EntList@) EntList@)) (entupd EntName^) );progn );if );if (setq Cnt# (1+ Cnt#)) );repeat (command "UNDO" "END") );progn );if );progn );if (princ) );defun FindReplaceAll ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; how can we use this code for selected objects instead of all objects in drawing? Quote Link to comment Share on other sites More sharing options...
Steven P Posted August 18, 2020 Share Posted August 18, 2020 Change this line: (if (setq SS& (ssget "x" (list '(-4 . "<AND")'(-4 . "<OR")'(0 . "TEXT")'(0 . "MTEXT")'(0 . "DIMENSION")'(0 . "INSERT")'(-4 . "OR>")(cons 410 (getvar "CTAB"))'(-4 . "AND>")))) to this (if (setq SS& (ssget (list '(-4 . "<AND")'(-4 . "<OR")'(0 . "TEXT")'(0 . "MTEXT")'(0 . "DIMENSION")'(0 . "INSERT")'(-4 . "OR>")(cons 410 (getvar "CTAB"))'(-4 . "AND>")))) should do it (The ssget "x" means select everything, take away the "x" and you are asked to select the objects) Quote Link to comment Share on other sites More sharing options...
bkartal16 Posted August 18, 2020 Share Posted August 18, 2020 1 hour ago, Steven P said: Change this line: (if (setq SS& (ssget "x" (list '(-4 . "<AND")'(-4 . "<OR")'(0 . "TEXT")'(0 . "MTEXT")'(0 . "DIMENSION")'(0 . "INSERT")'(-4 . "OR>")(cons 410 (getvar "CTAB"))'(-4 . "AND>")))) to this (if (setq SS& (ssget (list '(-4 . "<AND")'(-4 . "<OR")'(0 . "TEXT")'(0 . "MTEXT")'(0 . "DIMENSION")'(0 . "INSERT")'(-4 . "OR>")(cons 410 (getvar "CTAB"))'(-4 . "AND>")))) should do it (The ssget "x" means select everything, take away the "x" and you are asked to select the objects) thanx for help and information :) Quote Link to comment Share on other sites More sharing options...
yxl030 Posted October 23, 2021 Share Posted October 23, 2021 How to modify the LISP to replace the text in the blocks and nested blocks ? Or is there another way to do it ? On 7/18/2019 at 6:47 PM, Steven P said: This might give you a start, command txtreplace which you could modify to accept multiple inputs and then run the FindReplaceAll function for each letter. Note this is case sensitive. ;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/find-and-replace-text/td-p/5649883 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun c:txtreplace( / old_text new_text) (setq old_text (getstring T "OLD Text to replace (replace in this model/paper space and text case as entered): ")) (setq new_text (getstring T "NEW text to use: ")) (FindReplaceAll old_text new_text) (princ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; FindReplaceAll - Changes Text, Mtext, Dimensions and Attribute Block entities ; that have a Find$ string with a Replace$ string. ; Arguments: 2 ; Find$ = Phrase string to find ; Replace$ = Phrase to replace it with ; Syntax: (FindReplaceAll "old string" "new string") ; Returns: Updates Text, Mtext, Dimension and Attribute Block entities ; It is Case sensitive ;------------------------------------------------------------------------------- (defun FindReplaceAll (Find$ Replace$ / BlkEntList@ BlkEntName^ BlkEntType$ Cnt# DimEntList@ DimEntName^ DimEntType$ EntList@ EntName^ EntType$ FindReplace: Mid$ Mid2$ NewText$ Num# Replace$ SS& Text$) ;----------------------------------------------------------------------------- ; FindReplace: - Returns Str$ with Find$ changed to Replace$ ; Arguments: 3 ; Str$ = Text string ; Find$ = Phrase string to find ; Replace$ = Phrase to replace Find$ with ; Returns: Returns Str$ with Find$ changed to Replace$ ;----------------------------------------------------------------------------- (defun FindReplace: (Str$ Find$ Replace$ / Cnt# FindLen# Loop Mid$ NewStr$ ReplaceLen#) (setq Loop t Cnt# 1 NewStr$ Str$ FindLen# (strlen Find$) ReplaceLen# (strlen Replace$)) (while Loop (setq Mid$ (substr NewStr$ Cnt# FindLen#)) (if (= Mid$ Find$) (setq NewStr$ (strcat (substr NewStr$ 1 (1- Cnt#)) Replace$ (substr NewStr$ (+ Cnt# FindLen#))) Cnt# (+ Cnt# ReplaceLen#) );setq (setq Cnt# (1+ Cnt#)) );if (if (= Mid$ "") (setq Loop nil)) );while NewStr$ );defun FindReplace: ;----------------------------------------------------------------------------- ; Start of Main function ;----------------------------------------------------------------------------- (if (and (= (type Find$) 'STR)(= (type Replace$) 'STR)(/= Find$ "")) (progn (if (setq SS& (ssget "x" (list '(-4 . "<AND")'(-4 . "<OR")'(0 . "TEXT")'(0 . "MTEXT")'(0 . "DIMENSION")'(0 . "INSERT")'(-4 . "OR>")(cons 410 (getvar "CTAB"))'(-4 . "AND>")))) (progn (command "UNDO" "BEGIN") (setq Cnt# 0) (repeat (sslength SS&) (setq EntName^ (ssname SS& Cnt#) EntList@ (entget EntName^) EntType$ (cdr (assoc 0 EntList@)) Text$ (cdr (assoc 1 EntList@)) );setq (if (= EntType$ "INSERT") (if (assoc 66 EntList@) (progn (while (/= (cdr (assoc 0 EntList@)) "SEQEND") (setq EntList@ (entget EntName^)) (if (= (cdr (assoc 0 EntList@)) "ATTRIB") (progn (setq Text$ (cdr (assoc 1 EntList@))) (if (wcmatch Text$ (strcat "*" Find$ "*")) (progn (setq ReplaceWith$ (FindReplace: Text$ Find$ Replace$)) (entmod (subst (cons 1 ReplaceWith$) (assoc 1 EntList@) EntList@)) (entupd EntName^) );progn );if );progn );if (setq EntName^ (entnext EntName^)) );while );progn );if (if (wcmatch Text$ (strcat "*" Find$ "*")) (progn (setq ReplaceWith$ (FindReplace: Text$ Find$ Replace$)) (entmod (subst (cons 1 ReplaceWith$) (assoc 1 EntList@) EntList@)) (entupd EntName^) );progn );if );if (setq Cnt# (1+ Cnt#)) );repeat (command "UNDO" "END") );progn );if );progn );if (princ) );defun FindReplaceAll ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Quote Link to comment Share on other sites More sharing options...
