FIND AND REPLACE MULTYPLE LETTERS
Can we  Encoding to ANSI  the translate text ;
I check the language settings in windows and i canot see a problem.
The only think i notice is when i inport a text from txt file in mtext editor  AND THE TEXT IS UTF-8  I CANT RED THE TEXT. IF THE TEXT IS ANSI I HAVE NO PROBLEM
  • Replies 34
  • Steven P
    8
  • ronjonp
    4
  • bkartal16
    2
  • maratovich
    1
Posted Images
I put your text in and tried it - seams to work for me as it is
(defun c:multipletxtreplace( / echo_old replaceletter acount)
  (setq cmdecho_old (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq replaceletters (list
'("A" "Á")
'("B" "Â")
'("C" "×")
'("D" "Ä")
'("E" "Å")
'("F" "Ö")
'("G" "Ã")
'("H" "Ç")
'("I" "É")
'("K" "Ê")
'("L" "Ë")
'("M" "Ì")
'("N" "Í")
'("O" "Ï")
'("P" "Ð")
'("Q" "È")
'("R" "Ñ")
'("S" "Ó")
'("T" "Ô")
'("U" "Õ")
'("W" "Ù")
'("X" "Î")
'("Y" "Ø")
'("Z" "Æ")
  (setq account 0)
  (repeat (length replaceletters)
    (FindReplaceAll (nth 0 (nth account replaceletters)) (nth 1 (nth account replaceletters)) )
    (setq account (+ 1 account))
  (setvar "cmdecho" cmdecho_old)
(defun c:txtfindreplace (/ f00 e)
  (defun f00 (string)
    (vl-string-translate "ABCDEFGHIKLMNOPQRSTUWXYZ" "ÁÂ×ÄÅÖÃÇÉÊËÌÍÏÐÈÑÓÔÕÙÎØÆ" string)
  (if (and (setq e (car (entsel "\Pick text: ")))
	   (setq e (vlax-ename->vla-object e))
	   (vlax-property-available-p e 'textstring)
    (vla-put-textstring e (f00 (vla-get-textstring e)))
; FindReplaceAll - Changes Text, Mtext, Dimensions and Attribute Block entities
; that have a Find$ string with a Replace$ string.
; Arguments: 2
;   Find$ = Phrase string to find
;   Replace$ = Phrase to replace it with
; Syntax: (FindReplaceAll "old string" "new string")
; Returns: Updates Text, Mtext, Dimension and Attribute Block entities
; It is Case sensitive
(defun FindReplaceAll (Find$ Replace$ / BlkEntList@ BlkEntName^ BlkEntType$ Cnt#
  DimEntList@ DimEntName^ DimEntType$ EntList@ EntName^ EntType$ FindReplace:
  Mid$ Mid2$ NewText$ Num# Replace$ SS& Text$)
  ; FindReplace: - Returns Str$ with Find$ changed to Replace$
  ; Arguments: 3
  ;   Str$ = Text string
  ;   Replace$ = Phrase to replace Find$ with
  ; Returns: Returns Str$ with Find$ changed to Replace$
  (defun FindReplace: (Str$ Find$ Replace$ / Cnt# FindLen# Loop Mid$ NewStr$ ReplaceLen#)
    (setq Loop t Cnt# 1 NewStr$ Str$ FindLen# (strlen Find$) ReplaceLen# (strlen Replace$))
    (while Loop
      (setq Mid$ (substr NewStr$ Cnt# FindLen#))
      (if (= Mid$ Find$)
        (setq NewStr$ (strcat (substr NewStr$ 1 (1- Cnt#)) Replace$ (substr NewStr$ (+ Cnt# FindLen#)))
              Cnt# (+ Cnt# ReplaceLen#)
        );setq
        (setq Cnt# (1+ Cnt#))
      );if
      (if (= Mid$ "") (setq Loop nil))
    );while
    NewStr$
  );defun FindReplace:
  ; Start of Main function
  (if (and (= (type Find$) 'STR)(= (type Replace$) 'STR)(/= Find$ ""))
      (if (setq SS& (ssget "x" (list '(-4 . "<AND")'(-4 . "<OR")'(0 . "TEXT")'(0 . "MTEXT")'(0 . "DIMENSION")'(0 . "INSERT")'(-4 . "OR>")(cons 410 (getvar "CTAB"))'(-4 . "AND>"))))
          (command "UNDO" "BEGIN")
          (setq Cnt# 0)
          (repeat (sslength SS&)
            (setq EntName^ (ssname SS& Cnt#)
                  EntList@ (entget EntName^)
                  EntType$ (cdr (assoc 0 EntList@))
                  Text$ (cdr (assoc 1 EntList@))
            );setq
            (if (= EntType$ "INSERT")
              (if (assoc 66 EntList@)
                  (while (/= (cdr (assoc 0 EntList@)) "SEQEND")
                    (setq EntList@ (entget EntName^))
                    (if (= (cdr (assoc 0 EntList@)) "ATTRIB")
                        (setq Text$ (cdr (assoc 1 EntList@)))
                        (if (wcmatch Text$ (strcat "*" Find$ "*"))
                            (setq ReplaceWith$ (FindReplace: Text$ Find$ Replace$))
                            (entmod (subst (cons 1 ReplaceWith$) (assoc 1 EntList@) EntList@))
                            (entupd EntName^)
                          );progn
                        );if
                      );progn
                    );if
                    (setq EntName^ (entnext EntName^))
                  );while
                );progn
              );if
                  (entupd EntName^)
                );progn
              );if
            );if
          );repeat
          (command "UNDO" "END")
        );progn
      );if
    );progn
  );if
);defun FindReplaceAll
Its the weekend and AutoCAD is left in the office, howver what happens if you put the unicode code in instead of the letters?
For example '("A"  "\\U00C0") ?
  • 2 weeks later...
I replace the leters with unicaode characters but the text didn't change .Can any one tell were is the problem ?
(defun c:multipletxtreplace ( / cmdecho_old replaceletters acount)
  (setq replaceletters (list '("A" "\U+0391") '("B" "\U+0392") '("C" "\U+03A7") '("D" "\U+0394") '("E" "\U+0395") '("F" "\U+03A6") '("G" "\U+0393") '("H" "\U+0397") '("I" "\U+0399") '("K" "\U+039A") '("L" "\U+039B") '("M" "\U+039C") '("N" "\U+039D") '("O" "\U+039F") '("P" "\U+03A0") '("Q" "\U+0398") '("R" "\U+03A1") '("S" "\U+03A3") '("T" "\U+03A4") '("U" "\U+03A5") '("W" "\U+03A9") '("X" "\U+039E") '("Y" "\U+03A8") '("Z" "\U+0396")) ) ;;complete list as required.
  (setq account 0)
; Arguments: 2
  ; Arguments: 3
    (while Loop
      (if (= Mid$ Find$)
        );setq
      );if
    );while
    NewStr$
          (setq Cnt# 0)
            );setq
                            (entupd EntName^)
                          );progn
                        );if
                      );progn
                    );if
                  );while
                );progn
              );if
                  (entupd EntName^)
                );progn
              );if
            );if
          );repeat
        );progn
      );if
    );progn
  );if
Thanks
  • 1 year later...
On 7/18/2019 at 1:47 PM, Steven P said:
This might give you a start, command txtreplace which you could modify to accept multiple inputs and then run the FindReplaceAll function for each letter. Note this is case sensitive.
;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/find-and-replace-text/td-p/5649883
(defun c:txtreplace( / old_text new_text)
  (setq old_text (getstring T "OLD Text to replace (replace in this model/paper space and text case as entered): "))
  (setq new_text (getstring T "NEW text to use: "))
  (FindReplaceAll old_text new_text)
; Arguments: 2
  ; Arguments: 3
    (while Loop
      (if (= Mid$ Find$)
        );setq
      );if
    );while
    NewStr$
          (setq Cnt# 0)
            );setq
                            (entupd EntName^)
                          );progn
                        );if
                      );progn
                    );if
                  );while
                );progn
              );if
                  (entupd EntName^)
                );progn
              );if
            );if
          );repeat
        );progn
      );if
    );progn
  );if
how can we use this code for selected objects instead of all objects in drawing?
Change this line:
to this
(if (setq SS& (ssget (list '(-4 . "<AND")'(-4 . "<OR")'(0 . "TEXT")'(0 . "MTEXT")'(0 . "DIMENSION")'(0 . "INSERT")'(-4 . "OR>")(cons 410 (getvar "CTAB"))'(-4 . "AND>"))))
should do it (The ssget "x" means select everything, take away the "x" and you are asked to select the objects)
1 hour ago, Steven P said:
Change this line:
to this
thanx for help and information :)
  • 1 year later...
How to modify the LISP to replace the text in the blocks and nested blocks ?
Or is there another way to do it ?
; Arguments: 2
  ; Arguments: 3
    (while Loop
      (if (= Mid$ Find$)
        );setq
      );if
    );while
    NewStr$
          (setq Cnt# 0)
            );setq
                            (entupd EntName^)
                          );progn
                        );if
                      );progn
                    );if
                  );while
                );progn
              );if
                  (entupd EntName^)
                );progn
              );if
            );if
          );repeat
        );progn
      );if
    );progn
  );if
