FIND AND REPLACE MULTYPLE LETTERS
HI i am searching for a lisp to replace multyple letters from mtext
for exaple to replaxe  A,B,C,D,E,F,G,K,L,,M,N  WITH Α,Β,Γ,Δ,Ε,Ζ,Η,Θ,Ι,Κ ......
THANKS
  • Replies 34
  • Steven P
    8
  • ronjonp
    4
  • bkartal16
    2
  • maratovich
    1
Posted Images
This might give you a start, command txtreplace which you could modify to accept multiple inputs and then run the FindReplaceAll function for each letter. Note this is case sensitive.
;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/find-and-replace-text/td-p/5649883
(defun c:txtreplace( / old_text new_text)
  (setq old_text (getstring T "OLD Text to replace (replace in this model/paper space and text case as entered): "))
  (setq new_text (getstring T "NEW text to use: "))
  (FindReplaceAll old_text new_text)
; FindReplaceAll - Changes Text, Mtext, Dimensions and Attribute Block entities
; that have a Find$ string with a Replace$ string.
; Arguments: 2
;   Find$ = Phrase string to find
;   Replace$ = Phrase to replace it with
; Syntax: (FindReplaceAll "old string" "new string")
; Returns: Updates Text, Mtext, Dimension and Attribute Block entities
; It is Case sensitive
(defun FindReplaceAll (Find$ Replace$ / BlkEntList@ BlkEntName^ BlkEntType$ Cnt#
  DimEntList@ DimEntName^ DimEntType$ EntList@ EntName^ EntType$ FindReplace:
  Mid$ Mid2$ NewText$ Num# Replace$ SS& Text$)
  ; FindReplace: - Returns Str$ with Find$ changed to Replace$
  ; Arguments: 3
  ;   Str$ = Text string
  ;   Replace$ = Phrase to replace Find$ with
  ; Returns: Returns Str$ with Find$ changed to Replace$
  (defun FindReplace: (Str$ Find$ Replace$ / Cnt# FindLen# Loop Mid$ NewStr$ ReplaceLen#)
    (setq Loop t Cnt# 1 NewStr$ Str$ FindLen# (strlen Find$) ReplaceLen# (strlen Replace$))
    (while Loop
      (setq Mid$ (substr NewStr$ Cnt# FindLen#))
      (if (= Mid$ Find$)
        (setq NewStr$ (strcat (substr NewStr$ 1 (1- Cnt#)) Replace$ (substr NewStr$ (+ Cnt# FindLen#)))
              Cnt# (+ Cnt# ReplaceLen#)
        );setq
        (setq Cnt# (1+ Cnt#))
      );if
      (if (= Mid$ "") (setq Loop nil))
    );while
    NewStr$
  );defun FindReplace:
  ; Start of Main function
  (if (and (= (type Find$) 'STR)(= (type Replace$) 'STR)(/= Find$ ""))
      (if (setq SS& (ssget "x" (list '(-4 . "<AND")'(-4 . "<OR")'(0 . "TEXT")'(0 . "MTEXT")'(0 . "DIMENSION")'(0 . "INSERT")'(-4 . "OR>")(cons 410 (getvar "CTAB"))'(-4 . "AND>"))))
          (command "UNDO" "BEGIN")
          (setq Cnt# 0)
          (repeat (sslength SS&)
            (setq EntName^ (ssname SS& Cnt#)
                  EntList@ (entget EntName^)
                  EntType$ (cdr (assoc 0 EntList@))
                  Text$ (cdr (assoc 1 EntList@))
            );setq
            (if (= EntType$ "INSERT")
              (if (assoc 66 EntList@)
                  (while (/= (cdr (assoc 0 EntList@)) "SEQEND")
                    (setq EntList@ (entget EntName^))
                    (if (= (cdr (assoc 0 EntList@)) "ATTRIB")
                        (setq Text$ (cdr (assoc 1 EntList@)))
                        (if (wcmatch Text$ (strcat "*" Find$ "*"))
                            (setq ReplaceWith$ (FindReplace: Text$ Find$ Replace$))
                            (entmod (subst (cons 1 ReplaceWith$) (assoc 1 EntList@) EntList@))
                            (entupd EntName^)
                          );progn
                        );if
                      );progn
                    );if
                    (setq EntName^ (entnext EntName^))
                  );while
                );progn
              );if
                  (entupd EntName^)
                );progn
              );if
            );if
          );repeat
          (command "UNDO" "END")
        );progn
      );if
    );progn
  );if
);defun FindReplaceAll
You could use vl-string-translate:
(vl-string-translate "ABCD" "1234" "ABCD_ABCDDDDABCD_ABCDCCC")
;; Returns "1234_12344441234_1234333"
30 minutes ago, prodromosm said:
i want to translate this leters
characters.txt 216 B · 0 downloads
Try this:
(defun f00 (string)(vl-string-translate "ABCDEFGHIKLMNOPQRSTUWXYZ" "ÁÂ×ÄÅÖÃÇÉÊËÌÍÏÐÈÑÓÔÕÙÎØÆ" string))
(F00 "THIS IS MY HAPPY LITTLE STRING TO REPLACE WITH ODD CHARACTERS")
;; RESULT "ÔÇÉÓ ÉÓ ÌØ ÇÁÐÐØ ËÉÔÔËÅ ÓÔÑÉÍà ÔÏ ÑÅÐËÁ×Å ÙÉÔÇ ÏÄÄ ×ÇÁÑÁ×ÔÅÑÓ"
(defun f00 (string)(vl-string-translate "ABCDEFGHIKLMNOPQRSTUWXYZ" "ΑΒΧΔΕΦΓΗΙΚΛΜΝΟΠΘΡΣΤΥΩΞΨΖ" string))
is not working
is not working
I cannot read those symbols in your last example: "?????FG????????T?S??O???"
Edited by ronjonp
The idea is to replace each character with spesyfic other character.
for examle replace B with G , F with D ,H with S ..................   then i relace this letters with the correct
59 minutes ago, prodromosm said:
The problem is not the symbols i will change them .I sent a sample to understand how the text is
Works here although your formatting gets jacked:
(defun c:foo (/ f00 e)
  (defun f00 (string)
  (if (and (setq e (car (entsel "\Pick text: ")))
	   (setq e (vlax-ename->vla-object e))
	   (vlax-property-available-p e 'textstring)
    (vla-put-textstring e (f00 (vla-get-textstring e)))
I can not understand .Whrn i use Edit -> find and replace  the character is ok. When i use
vl-string-translate
  i can not red the text? is any other way to replace the text ?
This is a bit more long winded than ronjonp, not so nice to look at, use the FindReplaceAll that I posted above add this:
(defun c:multipletxtreplace( / cmdecho_old replaceletters acount)
  (setq cmdecho_old (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq replaceletters (list '("a" "A") '("b" "B") '("c" "C") '("d" "D") '("e" "E") '("f" "F")) ) ;;complete list as required.
  (setq account 0)
  (repeat (length replaceletters)
    (FindReplaceAll (nth 0 (nth account replaceletters)) (nth 1 (nth account replaceletters)) )
    (setq account (+ 1 account))
  (setvar "cmdecho" cmdecho_old)
Replace pairs of text in the replaceletters list in the form (list '( "old text" "new text" ) .... ).
Oh, 'FindReplaceAll' as it is will replace text in the whole model / paper space you are in at the time - not just selected text
Edited by Steven P
Hi Steven P. I update the code but give me an error
  (setq replaceletters (list '("A" "Α") '("B" "Β") '("C" "Χ") '("D" "Δ") '("E" "Ε") '("F" "Φ") '("G" "Γ") '("H" "Η") '("I" "Ι") '("K" "Κ") '("L" "Λ") '("M" "Μ") '("N" "Ν") '("O" "Ο") '("P" "Π") '("Q" "Θ") '("R" "Ρ") '("S" "Σ") '("T" "Τ") '("U" "Υ") '("W" "Ω") '("X" "Ξ") '("Y" "Ψ") '("Z" "Ζ")) ) ;;complete list as required.
  (setq account 0)
Quote
Command: MULTIPLETXTREPLACE
; error: no function definition: FINDREPLACEALL
That's strange, it should work OK. Just to check that you have both parts:
  (setq account 0)
; Arguments: 2
  ; Arguments: 3
    (while Loop
      (if (= Mid$ Find$)
        );setq
      );if
    );while
    NewStr$
          (setq Cnt# 0)
            );setq
                            (entupd EntName^)
                          );progn
                        );if
                      );progn
                    );if
                  );while
                );progn
              );if
                  (entupd EntName^)
                );progn
              );if
            );if
          );repeat
        );progn
      );if
    );progn
  );if
I can not understan why. Wheni i use Edit -> find and replace  the character is ok. When i use  a lisp to translate the letters  the text is not readable
