The AutoCAD Blog Posted July 18, 2019 Posted July 18, 2019 Asking yourself “Where in the world?” when it comes to raster images? Developer CAD Studio has created an easy way for georeferencing raster images in AutoCAD. GeoRefImg is a LISP utility for AutoCAD and the Architecture, MEP, and Plant 3D toolsets. It automatically repositions raster images used in a drawing to the position defined in the images’ world files, which define geo-position and other parameters of the raster image. “Start it by typing the GEOREFIMG command,” CAD Studio writes. “GeoRefImg prompts to select objects (existing images) and then performs the repositioning and scaling controlled by the World files (TFW, JGW, PGW, GFW, BPW, WLD, etc.). World files are searched in the folders of the original raster file. Use full paths (REFPATHTYPE=2). The additional command WORLDOUT can create a new world file from an existing positioned image.” Best part? It’s free! You can find the utility on the Autodesk App Store here. Check out the entire series for more indispensable AutoCAD apps available on the Autodesk App Store. The post LISP Utility Helps Georeferencing Raster Images in AutoCAD appeared first on AutoCAD Blog. View the full article Quote
BIGAL Posted July 19, 2019 Posted July 19, 2019 Been using this for years uses JGW. Saves the need to find. rescale image.lsp Quote
halam Posted May 16, 2021 Posted May 16, 2021 (edited) GeoREFIMG is AutoCAD only and will does not work. I am sure i have a geotiff. How does one create jgw files from geotiff to use the lisp? Edited May 16, 2021 by halam Quote
BIGAL Posted May 17, 2021 Posted May 17, 2021 Try "exiftool" it has all sorts of options to pull stuff out of images I used it to get lat long from Phone photos. Quote
