Please Help to Modify Code to Allow Select Various Objects
Can any of yall wise members of the forum give me a hand?
The goal it is modify this code to allow me to select several objects at the same time.
This is a LISP that creates dimensions around polylines under some parameters.  My problem is that only lets me select 1 object (polyline) at a time.
I would like the program to ask me for "select objects" (plural)  in the first place.
My name is Juan,  and I would really apreciate your help  :)
(defun c:ADIM (/       *error* mid     add:dim calc:p  calc:ang
           add:arc add:raddim      s       l       p       ol
           fl      cm      os      cen
  (MSM:STARTUNDOMARK)
  (defun *error* (msg)
    (if    os
      (setvar 'osmode os)
    (if    cm
      (setvar 'cmdecho cm)
    (MSM:ENDUNDOMARK)
    (if    (not
      (wcmatch (strcase msg t) "*break,*cancel*,*exit*,*erased")
      (princ "\nStatus = Function Cancelled")
  (defun mid (p1 p2)
    (mapcar '(lambda (x1 x2) (/ (+ x1 x2) 2.0)) p1 p2)
  (defun add:dim (p1 p2 p3 / e d)
    (setq e (entlast))
    (command "DIMALIGNED" p1 p2 p3)
    (if    (and (setq d (entlast))
         (/= e d)
         (setq d (vlax-ename->vla-object d))
         (wcmatch (vla-get-objectname d) "*Dimension")
    (vla-put-layer d "AUTO DIM")
    (if (tblsearch "dimstyle" "Standard")
      (vla-put-stylename d "DIM")
  (defun calc:p    (p1 p2 b / a c r)
    (setq a (* 2 (atan b))
      r (/ (distance p1 p2) 2 (sin a))
      c (polar p1 (+ (- (/ pi 2) a) (angle p1 p2)) r)
    (if    (minusp b)
      (list c (angle c p2) (angle c p1) (abs r))
      (list c (angle c p1) (angle c p2) (abs r))
  (defun calc:ang (pnt / an)
    (if    (setq an (angle cen pnt))
      (cond ((<= (* pi 0.25) an (* pi 0.75)) (* pi 0.5))
        ((<= (* pi 0.75) an (* pi 1.25)) pi)
        ((<= (* pi 1.25) an (* pi 1.75)) (* pi 1.5))
        ((<= (* pi 1.75) an (* pi 2.0)) 0.0)
        ((<= 0.0 an (* pi 0.25)) 0.0)
  (defun add:arc (p1 p2 b)
    (entmakex
      (cons '(0 . "ARC")
        (mapcar 'cons
            '(10 50 51 40)
            (calc:p p1 p2 b)
  (defun add:raddim (p1 p2 b / e d arc p3)
    (if    (setq arc (add:arc p1 p2 b))
    (setq e (entlast))
    (setq arc (vlax-ename->vla-object arc))
    (setq p3
           (vlax-curve-getpointatdist e (/ (vla-get-arclength arc) 2.))
    (command "DIMRADIUS"
         (list (vlax-vla-object->ename arc) p3)
         (vlax-get arc 'center)
    (setq d (entlast))
    (if (and (/= e d)
        (vla-put-arrowheadtype d 0)
        (vla-put-arrowheadsize d 1.7)
    (vla-delete arc)
    d
  (cond
    ((not (setq s (car (entsel "\nSelect Polyline : "))))
     (alert "Nothing selected.")
    ((not
       (wcmatch (cdr (assoc 0 (setq s (entget s)))) "*POLYLINE")
     (alert "Please select Polyline object.")
    (t
     (setq cm (getvar 'cmdecho)
       os (getvar 'osmode)
     (setvar 'cmdecho 0)
     (setvar 'osmode 0)
     (if (not (tblsearch "LAYER" "AUTO DIM"))
       (MSM:LAYER "AUTO DIM" 0 7 "Continuous")
     (setq cen (LM:PolyCentroid (cdr (assoc -1 s))))
     (setq l (vl-remove-if-not
           '(lambda    (x)
          (member (car x) '(10 42))
           s
     (if (eq (cdr (assoc 70 s)) 1)
       (setq
     l (reverse (cons (cons 42 0.0) (cons (car l) (reverse l))))
     (setq s (vlax-ename->vla-object (cdr (assoc -1 s))))
     (setq p (vl-remove    nil
            (mapcar
              '(lambda (x y z)
                 (if (eq (car x) 10)
                   (list x y z)
              l
              (cdr l)
              (cddr l)
     (setq
       ol (mapcar '(lambda (x)
             (if (zerop (cdr (cadr x)))
               (MSM:LINE (vla-get-layer s)
                 (vla-get-color s)
                 (cdr (car x))
                 (cdr (caddr x))
             (add:raddim
               (cdr (car x))
               (cdr (caddr x))
               (cdr (cadr x))
             "F"
          p
     (if (member "F" ol)
     (setq
       fl (mapcar
        '(lambda (x y z)
           (if (eq y "F")
             (list x y z)
        ol
        (reverse (cons (car ol) (reverse (cdr ol))))
        (reverse
          (cons (cadr ol) (cons (car ol) (reverse (cddr ol))))
     (foreach x fl
       (command "chamfer" (car x) (caddr x))
     (mapcar
       '(lambda    (x / x1 x2 xa xp)
      (if (and (/= (type x) 'STR)
           (setq x1 (cdr (assoc 10 (entget x))))
           (setq x2 (cdr (assoc 11 (entget x))))
           (> (distance x1 x2) 20.)
          (setq xa (angle x1 x2))
          (setq xp (mid x1 x2))
          (setq xp (polar xp (calc:ang xp) 3.7))
          (add:dim x1 x2 xp)
       ol
     (vla-delete s)
     (setvar 'osmode os)
  (MSM:ENDUNDOMARK)
(VL-LOAD-COM)
(PRINC)
(PRINC
  (STRCAT
    "\n:: Add Dimensions_V1.lsp ::"
    "\n:: Created by Satish Rajdev | "
    (MENUCMD "M=$(edtime,$(getvar,date),DDDD\",\" D MONTH YYYY)"
    "\n:: Type \"ADIM\" to Invoke ::"
(SETQ MSM:ACAD    (VLAX-GET-ACAD-OBJECT)
      MSM:ACDOC    (VLA-GET-ACTIVEDOCUMENT MSM:ACAD)
      MSM:MODEL    (VLA-GET-MODELSPACE MSM:ACDOC)
(DEFUN MSM:STARTUNDOMARK ()
  (MSM:ENDUNDOMARK)
  (VLA-STARTUNDOMARK MSM:ACDOC)
(DEFUN MSM:ENDUNDOMARK ()
  (VLA-ENDUNDOMARK MSM:ACDOC)
(DEFUN MSM:LINE    (LAYER COLOR STARTPOINT ENDPOINT)
  (ENTMAKEX (LIST '(0 . "LINE")
          '(100 . "AcDbEntity")
          (CONS 8 LAYER)
          (CONS 62 COLOR)
          (CONS 100 "AcDbLine")
          (CONS 10 STARTPOINT)
          (CONS 11 ENDPOINT)
(DEFUN MSM:LAYER (NAME FLAG COLOR LINETYPE)
  (ENTMAKE (LIST
         '(0 . "LAYER")
         (CONS 100 "AcDbSymbolTableRecord")
         (CONS 100 "AcDbLayerTableRecord")
         (CONS 2 NAME)
         (CONS 70 FLAG)
         (CONS 62 COLOR)
         (CONS 6 LINETYPE)
(defun LM:PolyCentroid (e / l)
  (foreach x (setq e (entget e))
    (if    (= 10 (car x))
      (setq l (cons (cdr x) l))
   (lambda (a)
     (if (not (equal 0.0 a 1e-8))
       (trans
     (mapcar
       (apply
         'mapcar
         (cons '+
           (mapcar
             (function
               (lambda (a b)
              (lambda (m)
                (mapcar
                  (function
                (lambda (c d) (* (+ c d) m))
                  a
                  b
               (- (* (car a) (cadr b)) (* (car b) (cadr a)))
             l
             (cons (last l) l)
       (list a a)
     (cdr (assoc 210 e))
     0
    (* 3.0
       (apply '+
          (mapcar
        (function
          (lambda (a b)
        l
        (cons (last l) l)
(PRINC)
Edited by jvelasco
(defun c:ADIM  (/ *error* mid add:dim calc:p calc:ang add:arc add:raddim s l p ol fl cm os cen ss)
  (MSM:STARTUNDOMARK)
  (defun *error* (msg) (if os (setvar 'osmode os)) (if cm (setvar 'cmdecho cm)) (MSM:ENDUNDOMARK)
    (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*,*erased"))(princ "\nStatus = Function Cancelled"))(princ))
  (defun mid (p1 p2) (mapcar '(lambda (x1 x2) (/ (+ x1 x2) 2.0)) p1 p2))
  (defun add:dim (p1 p2 p3 / e d)(setq e (entlast))(command "DIMALIGNED" p1 p2 p3)
    (if (and (setq d (entlast))(/= e d)(setq d (vlax-ename->vla-object d))(wcmatch (vla-get-objectname d) "*Dimension"))
      (progn (vla-put-layer d "AUTO DIM")(if (tblsearch "dimstyle" "Standard")(vla-put-stylename d "DIM")))))
  (defun calc:p (p1 p2 b / a c r)(setq a (* 2 (atan b)) r (/ (distance p1 p2) 2 (sin a)) c (polar p1 (+ (- (/ pi 2) a) (angle p1 p2)) r))
    (if (minusp b)(list c (angle c p2) (angle c p1) (abs r))(list c (angle c p1) (angle c p2) (abs r))))
  (defun calc:ang  (pnt / an) (if (setq an (angle cen pnt))(cond ((<= (* pi 0.25) an (* pi 0.75)) (* pi 0.5))
    ((<= (* pi 0.75) an (* pi 1.25)) pi)((<= (* pi 1.25) an (* pi 1.75)) (* pi 1.5))((<= (* pi 1.75) an (* pi 2.0)) 0.0)
      ((<= 0.0 an (* pi 0.25)) 0.0))))
  (defun add:arc (p1 p2 b)(entmakex (cons '(0 . "ARC")(mapcar 'cons '(10 50 51 40) (calc:p p1 p2 b)))))
      (progn (setq e (entlast))(setq arc (vlax-ename->vla-object arc))
             (setq p3 (vlax-curve-getpointatdist e (/ (vla-get-arclength arc) 2.)))
             (command "DIMRADIUS" (list (vlax-vla-object->ename arc) p3)(vlax-get arc 'center))
             (setq d (entlast))
             (if (and (/= e d)(setq d (vlax-ename->vla-object d))(wcmatch (vla-get-objectname d) "*Dimension"))
                      (vla-put-arrowheadtype d 0)(vla-put-arrowheadsize d 1.7)))(vla-delete arc) d)))
  (cond
    ;((not (setq s (car (entsel "\nSelect Polyline : ")))) (alert "Nothing selected."))
    ;((not (wcmatch (cdr (assoc 0 (setq s (entget s)))) "*POLYLINE"))(alert "Please select Polyline object."))
    ((not (setq ss (ssget '((0 . "*POLYLINE")))))(alert "No polylines were selected"))
    (t
     (setq cm (getvar 'cmdecho) os (getvar 'osmode))(setvar 'cmdecho 0)(setvar 'osmode 0)
     (if (not (tblsearch "LAYER" "AUTO DIM"))(MSM:LAYER "AUTO DIM" 0 7 "Continuous"))
     (foreach s (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
       (setq s (entget s) cen (LM:PolyCentroid (cdr (assoc -1 s))))
       (setq l (vl-remove-if-not '(lambda (x) (member (car x) '(10 42))) s))
       (if (eq (cdr (assoc 70 s)) 1)(setq l (reverse (cons (cons 42 0.0) (cons (car l) (reverse l))))))
       (setq p (vl-remove nil (mapcar '(lambda (x y z)(if (eq (car x) 10)(list x y z))) l (cdr l)(cddr l))))
       (setq ol (mapcar '(lambda (x) (if (zerop (cdr (cadr x))) (MSM:LINE (vla-get-layer s)(vla-get-color s)(cdr (car x))(cdr (caddr x)))
                           (progn (add:raddim (cdr (car x))(cdr (caddr x))(cdr (cadr x))) "F"))) p))
       (if (member "F" ol)
         (progn (setq fl (mapcar '(lambda (x y z)(if (eq y "F")(list x y z))) ol (reverse (cons (car ol) (reverse (cdr ol))))
                       (reverse (cons (cadr ol) (cons (car ol) (reverse (cddr ol))))))) (foreach x fl (command "chamfer" (car x) (caddr x)))))
       (mapcar '(lambda (x / x1 x2 xa xp)
         (if (and (/= (type x) 'STR)(setq x1 (cdr (assoc 10 (entget x))))(setq x2 (cdr (assoc 11 (entget x))))(> (distance x1 x2) 20.))
           (progn (setq xa (angle x1 x2))(setq xp (mid x1 x2))(setq xp (polar xp (calc:ang xp) 3.7))(add:dim x1 x2 xp)))) ol)
       (vla-delete s)
     (setvar 'osmode os)(setvar 'cmdecho cm)
   ); end t
  ); end cond
  (MSM:ENDUNDOMARK)
(VL-LOAD-COM)(PRINC)(PRINC (STRCAT "\n:: Add Dimensions_V1.lsp ::\n:: Created by Satish Rajdev | "
          (MENUCMD "M=$(edtime,$(getvar,date),DDDD\",\" D MONTH YYYY)") " ::\n:: Type \"ADIM\" to Invoke ::"))
(SETQ MSM:ACAD  (VLAX-GET-ACAD-OBJECT) MSM:ACDOC (VLA-GET-ACTIVEDOCUMENT MSM:ACAD) MSM:MODEL (VLA-GET-MODELSPACE MSM:ACDOC))
(DEFUN MSM:STARTUNDOMARK ()(MSM:ENDUNDOMARK)(VLA-STARTUNDOMARK MSM:ACDOC))
(DEFUN MSM:ENDUNDOMARK () (VLA-ENDUNDOMARK MSM:ACDOC))
(DEFUN MSM:LINE (LAYER COLOR STARTPOINT ENDPOINT)(ENTMAKEX (LIST '(0 . "LINE") '(100 . "AcDbEntity")
  (CONS 8 LAYER)(CONS 62 COLOR)(CONS 100 "AcDbLine")(CONS 10 STARTPOINT)(CONS 11 ENDPOINT))))
(DEFUN MSM:LAYER  (NAME FLAG COLOR LINETYPE)(ENTMAKE (LIST '(0 . "LAYER")(CONS 100 "AcDbSymbolTableRecord")
  (CONS 100 "AcDbLayerTableRecord")(CONS 2 NAME)(CONS 70 FLAG)(CONS 62 COLOR)(CONS 6 LINETYPE))))
  (foreach x  (setq e (entget e))(if (= 10 (car x))(setq l (cons (cdr x) l))))
  ((lambda (a)
       (trans (mapcar '/ (apply 'mapcar (cons '+ (mapcar (function (lambda (a b)((lambda (m)(mapcar (function (lambda (c d) (* (+ c d) m)))
          a b))(- (* (car a) (cadr b))(* (car b) (cadr a)))))) l (cons (last l) l))))(list a a)) (cdr (assoc 210 e)) 0)))
    (* 3.0 (apply '+ (mapcar (function (lambda (a b) (- (* (car a) (cadr b)) (* (car b) (cadr a))))) l (cons (last l) l))))))
(PRINC)
Beaten to it :P :beer:
           fl      cm      os      cen     ss      cnt
  (MSM:STARTUNDOMARK)
    (if    os
      (setvar 'osmode os)
    (if    cm
    (MSM:ENDUNDOMARK)
    (if    (not
  (defun mid (p1 p2)
    (setq e (entlast))
         (/= e d)
    (if    (minusp b)
    (entmakex
      (cons '(0 . "ARC")
        (mapcar 'cons
            '(10 50 51 40)
            (calc:p p1 p2 b)
    (setq e (entlast))
    (setq p3
    (setq d (entlast))
    (if (and (/= e d)
    (vla-delete arc)
    d
  (prompt "\nSelect Polylines : ")
  (cond
    (ss
            os (getvar 'osmode)
      (setvar 'cmdecho 0)
      (setvar 'osmode 0)
      (repeat (setq cnt (sslength ss))
        (setq s (ssname ss (setq cnt (1- cnt)))
              cen (LM:PolyCentroid s)
              s (entget s)
          (mapcar
            '(lambda (x y z)
              (if (eq (car x) 10)
                (list x y z)
            l
            (cdr l)
            (cddr l)
        (setq ol
          (mapcar '
            (lambda (x)
                  (vla-get-color s)
                  (cdr (car x))
                  (cdr (caddr x))
                  (add:raddim
                    (cdr (car x))
                    (cdr (caddr x))
                    (cdr (cadr x))
                  "F"
            p
        (if (member "F" ol)
            (setq fl  (mapcar '(lambda (x y z) (if (eq y "F") (list x y z))) ol
            (foreach x fl
        (mapcar
                (add:dim x1 x2 xp)
          ol
        (vla-delete s)
      (setvar 'osmode os)
  (MSM:ENDUNDOMARK)
(VL-LOAD-COM)
(PRINC)
(PRINC
  (STRCAT
  (MSM:ENDUNDOMARK)
          (CONS 8 LAYER)
          (CONS 62 COLOR)
          (CONS 11 ENDPOINT)
  (ENTMAKE (LIST
         '(0 . "LAYER")
         (CONS 2 NAME)
         (CONS 70 FLAG)
         (CONS 62 COLOR)
         (CONS 6 LINETYPE)
    (if    (= 10 (car x))
   (lambda (a)
       (trans
     (mapcar
       (apply
         'mapcar
         (cons '+
           (mapcar
             (function
               (lambda (a b)
              (lambda (m)
                (mapcar
                  (function
                  a
                  b
             l
             (cons (last l) l)
       (list a a)
     (cdr (assoc 210 e))
     0
    (* 3.0
       (apply '+
          (mapcar
        (function
          (lambda (a b)
        l
        (cons (last l) l)
(PRINC)
haha , fortunately its not a contest , just helping others to find freeware 🤣
To both :
Probably you wanted to code :
(setq ss (ssget '((0 . "LWPOLYLINE"))))
For "*POLYLINE" CAD will look and for heavy and for 3d polylines, and in both cases it will fail - only with LWPOLYLINEs I suppose should be well and correct...
59 minutes ago, marko_ribar said:
To both :
not really ... but then I never / rarely use heavy or 3d poly's  😁 so good to know 🤓
thanx marko :beer:
Edited by rlx
rlx if you do a get coordinates it will return X Y X Y for 2D and X Y Z X Y Z for 3D polys, if your making lists will screw up. do a loop 2 or loop 3.
Edited by BIGAL
Good to know Bigal :thumbsup:
  • 3 weeks later...
thank you for your help. I didnt realized you guys responded, I was waiting for a notification in my mail.
I really apreciate it!!  :)
Go to your Account Settings and check your Notification Settings.
