AbdRF Posted August 5, 2019 Posted August 5, 2019 Hi all, I am learning lisp programming.Here is the code which I am a trying to run (defun c:tex (/ p1 a b c d e f) (setq pl (getpoint "\nStarting point: ")) (setq a (getdist p1 "\nEnter height: ")) (setq c (getdist p1 "\nline spacing: ")) (setq d "T") (while d (setq e (getstring 1 "Text: ")) (command "text" pl a "0" e) (setq pl (list (car p1)(- (cadr p1) c))) (setq f (getstring)) (if (= f "*")(setq d nil)) ) (princ) ) I am getting the below error.Can somebody explain me ? Quote Starting point: ; error: bad argument type: point: nil Quote
Roy_043 Posted August 5, 2019 Posted August 5, 2019 You have a variable pl (PL) and a variable p1 (P one). Quote
David Bethel Posted August 5, 2019 Posted August 5, 2019 You may want to look into (initget) call prior to (get.... ) calls. -David (defun c:foo (/ p1 a c) (initget 1) (setq p1 (getpoint "\nStarting Point: ")) (initget 6) (setq a (getdist p1 (strcat "\nTEXT Height <" (rtos (getvar "TEXTSIZE") 2 2) ">: "))) (or a (setq a (getvar "TEXTSIZE"))) (setvar "TEXTSIZE" a) (initget 7) (setq c (getdist p1 "\nLine Spacing": "))) ...) Quote
BIGAL Posted August 6, 2019 Posted August 6, 2019 (edited) My $0.05 using a library routine. If ran again both variables can be set to update. (if (not AH:getvalsm)(load "Multi Getvals.lsp")) (setq ans (AH:getvalsm (list "Enter values" "Text height" 5 4 (rtos (getvar "textsize")) "Line spacing " 5 4 "1" ))) Edited August 6, 2019 by BIGAL Quote
AbdRF Posted August 7, 2019 Author Posted August 7, 2019 On 8/5/2019 at 12:53 PM, Roy_043 said: You have a variable pl (PL) and a variable p1 (P one). Oh that was so silly on my part. Thanks Quote
AbdRF Posted August 7, 2019 Author Posted August 7, 2019 (edited) On 8/5/2019 at 3:35 PM, David Bethel said: You may want to look into (initget) call prior to (get.... ) calls. -David (defun c:foo (/ p1 a c) (initget 1) (setq p1 (getpoint "\nStarting Point: ")) (initget 6) (setq a (getdist p1 (strcat "\nTEXT Height <" (rtos (getvar "TEXTSIZE") 2 2) ">: "))) (or a (setq a (getvar "TEXTSIZE"))) (setvar "TEXTSIZE" a) (initget 7) (setq c (getdist p1 "\nLine Spacing": "))) ...) Sure David,will try this out . Cheers Edited August 7, 2019 by AbdRF Quote
