rog1n Posted August 5, 2019 Posted August 5, 2019 (edited) Hello, I am working now with DCL, I need when a select a radio_button change the label of toggle, after a search I think it is not possible, so I thought if use a toogle without label and a text on right of toogle like that: fr_config:dialog{ :boxed_row{ label="Options"; :radio_button{ label="Option 1"; key="1"; } :radio_button{ label="Option 2"; key="2"; } } :boxed_row{ label="Example"; :toggle{ alignment="rigth"; key= "toggle1"; } :text{ alignment="left"; key= "text1"; label = "Text"; } } spacer; ok_cancel; } but I couldn't put them (toggle and text) together... What I am doing wrong or maybe have a better solution? Edited August 5, 2019 by rog1n Quote
Tharwat Posted August 5, 2019 Posted August 5, 2019 An example: : boxed_row { fixed_width = true; : toggle { key = "tog1";} : text { label = "Initial name"; key = "t1";}} Then you need to add an action_tile for the radio_button to control the text by its key with your desired name. Quote
