Call Command based on a String Var
thebiglebowski
Is it possible to run a Command based on a value taken from a String Variable?
Something like this for example.
(setq comvar "_LINE")
and then later in the routine.
(Command (comvar))       to launch the line command?
I would like to launch the command directly from the String without using any corresponding "if" statement.
The purpose of this would be to run a command based off of the name of the block.
Ive been playing with this but I cannot get it to work.
Link to post
thebiglebowski
5 hours ago, BIGAL said:
: (command comvar)
: _LINE
Start of line:nil
Start of line:
Worked ?
Thanks,
I have no idea why I couldn't get this to work. Must have been tired.
Link to post
  • 1 year later...
jonathann3891
I have a similar issue, but I cannot get it to work.
I'm setting the variable which is also the command name like this:
(setq Comvar (strcat "pschformat_" usel))
usel is set by selection using initget.
(initget 1 "Imperial Metric")
  (setq Usel (getkword (strcat "\nSpecify Units [Imperial/Metric]:")))
  (cond
    ((= Usel "Imperial")(setvar 'insunits 1))
    ((= Usel "Metric")(setvar 'insunits 4))
    );cond
!Comvar will either equal "pschformat_imperial" or "pschformat_metric", which is a command in my lisp
;; Format table column width for Imperial
(defun c:pschformat_imperial (/ tbl)
  (vl-load-com)
  (setq tbl (vlax-ename->vla-object(car(entsel))))
  (vla-setcolumnwidth tbl 0 0.805) ;Set Column 0 Width to 0.805
  (vla-setcolumnwidth tbl 1 0.736) ;Set Column 1 Width to 0.375
  (vla-setcolumnwidth tbl 2 0.735) ;Set Column 2 Width to 0.590
  (vla-setcolumnwidth tbl 3 1) ;Set Column 3 Width to 1
  (vla-setcolumnwidth tbl 4 1) ;Set Column 4 Width to 1
  (vla-setcolumnwidth tbl 5 1) ;Set Column 5 Width to 1
  (vla-setcolumnwidth tbl 6 0.805) ;Set Column 6 Width to 0.805
  (vla-setrowheight tbl 0 0.3)
    (StripMtext (ssget "x") "*^L") ;Run StripMText ~ Remove All Formatting
;; Format table column width for metric
(defun c:pschformat_metric (/ tbl)
  (vl-load-com)
  (vla-setcolumnwidth tbl 0 20.4470) ;Set Column 0 Width to 0.805
  (vla-setcolumnwidth tbl 1 18.6944) ;Set Column 1 Width to 0.375
  (vla-setcolumnwidth tbl 2 18.6690) ;Set Column 2 Width to 0.590
  (vla-setcolumnwidth tbl 3 25.4000) ;Set Column 3 Width to 1
  (vla-setcolumnwidth tbl 4 25.4000) ;Set Column 4 Width to 1
  (vla-setcolumnwidth tbl 5 25.4000) ;Set Column 5 Width to 1
  (vla-setcolumnwidth tbl 6 20.4470) ;Set Column 6 Width to 0.805
When I try
: (Command Comvar)
I get the following error:
pschformat_Imperial Unknown command "PSCHFORMAT_IMPERIAL".
Edited by jonathann3891
Link to post
Jonathan Handojo
You are attempting to launch an AutoLISP function, not an AutoCAD command. Therefore you end up with that error. Having a function with a prefix "c:" only makes it so that the function can be called from the command line. To launch it, you'll need to go for a different approach.
((eval (read comvar)))
Edited by Jonathan Handojo
Link to post
