create automatic level in metric
Can any body convert the below lisp which is in decimal feet system format which i require to be in metric system...?
The below lisp works for Imperial cad template file well, but I require to function in a Metric template.
I want a lisp to convert an elevation text (ex: El. 245.00) to El. 255.00 when I apply this command and move a relative distance of 10 m....? Hope I explained clearly...
this would be very useful to me...
(Defun c:BT()
  (Setq sst(ssget)
    sset(ssget "p" '((0 . "text")))
    tv (cdr(Assoc 1 (Entget(ssname sset 0)))))
  (command "move" sst "" "@" "@")
  (setq lset (ssget "p" '((0 . "line"))))
    (Setq st 1)
  (while (= 0.0 (ATOF (substr tv st 1)))
    (Setq st (+ 1 st)))
  (Setq et 1)
  (while (/=  "\""  (substr tv et 1))
    (Setq et (+ 1 et)))
  (setq str(distof (substr tv st
            (- et st))))
  (command "copy" sset "" (setq a (getpoint "\n Specify the source point: "))
       (Setq b(getpoint "\n Specify the Desitnation point: " a)))
(if (< (- (cadr a )(cadr b)) 0)
  (command "change" (entlast) "" "" "" "" "" "" (strcat "EL. "(rtos (+ str (- (cadr B )(cadr A)))4 2)""))
  (command "change" (entlast) "" "" "" "" "" "" (strcat "EL. "(rtos (+ str (- (cadr B )(cadr A)))4 2)"")))
  (command "Copy" lset "" a b)
