NIEKO
EXTRACT ONLY THE "TEXTSIZE"/"TEXTHEIGHT" VALUE FROM A STRING OF TEXT
NIEKO
EXAMPLE 01 - 5mm HIGH TEXT
"100mm THICK MILD STEEL FLAT BAR"
above is a string of text on a drawing ------ question is as follows____how can I extract or obtain (with a lisp function) only the "textsize"/"textheight" value from the string to
use the value in a lisp routine
appreciated
NIEKO
Share this post
Link to post
Emmanuel Delay
Open a notepad document, copy/paste this code, save as print_text_height.lsp (feel free to rename, but keep the .lsp, and make sure ther's no .txt at the end of that).
Drag the .lsp file in your Autocad active document
Type command GTH, press enter
(defun c:gth ( / th)
  (setq th (cdr (assoc 40 (entget (car (entsel "\nSelect TEXT object: "))))))
  (princ "\nText height: ")
  (princ th)
Share this post
Link to post
NIEKO
Emmanuel
Thanks a lot. I really appretiate it
NIEKO
Share this post
Link to post
BIGAL
Another same thing using v lisp
(setq obj (vlax-ename->vla-object (car (entsel "pick text object"))))
(setq ht (vla-get-height obj))
(alert (strcat "height is  " (rtos ht 2 1)))
Share this post
Link to post
NIEKO
BIGAL
Thanks a lot for your help and input
I appreciate it very much
I would like to compliment all you guys for an excellent CAD forum
NIEKO
Share this post
Link to post
ronjonp
If you want the actual height of the text in the drawing use the TEXTBOX function. A string with the same height like "1234" will not be the same physical height as "{1234,".
Try it :)
(if (setq e (car (entsel "\nPick text: ")))
  (print (abs (apply '- (mapcar 'cadr (textbox (entget e))))))
  • Like 2
Share this post
Link to post
BIGAL
Good one ronjonp,  don't forget droppers, superscript, subscript.
Jj Ggx²
Share this post
Link to post
