Surveyor Brian
Survey bearing degree symbol
Surveyor Brian
why does my degree symbol print as a filled donut, with a very small inner circle diameter, when a circle in acad?
Share this post
Link to post
SLW210
Hard to say without seeing a .dwg and probably your plot settings.
Share this post
Link to post
Dana W
Quite simple.
Your lineweight (width) is wider than the hole in your "o".
0.25mm is your default lineweight setting, but your PLOTSTYLE named brian.ctb is unavailable to me so I have no idea what that does to your lines.
Solutions ARE, reduce the lineweight for the layer(s) containing "bears", (probably in your PLOTSTYLE) or select a font that has a larger symbol set.
Edited by Dana W
ADDED MORE INFO
Share this post
Link to post
rkmcswain
...or use a truetype font for at least the degree symbol. Truetype font characters scale their own "lineweight" based on font size, and not by any CTB/STB settings.
  • Thanks 1
Share this post
Link to post
Surveyor Brian
Bureaucracy dictates that I must not change lineweight.  Alpha and number characters must stay as close as poss to existing text style.  Thank you Dana for your comments, I will research size of symbol sets for various fonts.
R K McSwain I think what you have shown is just what I need, thank you.  Can you advise what true type font you used and I will attempt to acquire / use it?
Share this post
Link to post
Surveyor Brian
Solved, thanks to all.  True Type Font the solution.
Share this post
Link to post
tombu
I used AutoCAD's "Swis721 Lt BT" as my default for years because it uses less ink and is easily readable while using less space than most fonts, but switched to "Arial Narrow" as it's more compact and readable. I use Arial & Arial Bold sparingly on Index sheets.  For street signs "Lucida Sans Typewriter" uppercase letters are spot on.  Avoid purchasing that cool looking font online that may cause AutoCAD issues later on and will never look the same for anyone outside your office who didn't purchase it as well.  Huge assortment of fonts installed with Windows (almost everyone has) that AutoCAD is fully compatible with.
Share this post
Link to post
BIGAL
As a surveyor you may have rules about what font to use I know that here in AUS stuff like how a 4 looks, degree symbol, decimal point, are a couple that will reject a plan at the surveyors board, so find a TTF that reflects the standard required as close as you can get.
  • Thanks 1
Share this post
Link to post
