Juergen Posted August 19, 2019 Share Posted August 19, 2019 Hi everybody! I found the lisp EXT in a forum, that write the coordinates from text into a .csv file. Who can help me do add the text rotation after Text Value. Thanks for your help. EXT.LSP Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 19, 2019 Share Posted August 19, 2019 Thought I would give you most of the answer its two parts Angle is (50 . 0.816225398858982) ie (cdr (assoc 50 eb)) but this is radians no matter what your settings. so (defun rtd (a)(/ (* a 180.0) pi)) converts radians to degrees. You should be able to work out the rest in the STRCAT write-line. Use (entget (car (entsel))) I just type it on the command line to see the values for the assoc DXF codes. Quote Link to comment Share on other sites More sharing options...
