Does anyone know where I can get additional vehicles for Autodesk Vehicle Tracking? I've Google searched but drawing a blank.
If its like Autoturn you can add vehicles you need the manufacturers specifications. Start with something close.
I have done this for a BMW 5 series saloon but to be honest I'm not confident that I got it perfectly correct and fudged it slightly. I has hoping someone with more experience had done some.
4 hours ago, SLW210 said:
What version are you using?
See if THIS helps.
And THIS
2019 version. I believe the extended libraries are already included.
Here in AUS we have what is known as a 85% vehicle so you would not check for a particular BMW. As a side note crawled around a carpark measuring floor to lowest part on cars one of the better for clearance was a BMW.
Have had the problem of a Lotus though.
Agree with SLW210 last time I looked it had extensive library of vehicles as I needed a fire truck. Found a europenan one that was close.
Edited by BIGAL
Did you look at the second link? It has a tutorial on creating custom vehicles.
Pretty straight forward to create your own, shouldn't be too difficult to get the pertinent information and adjust a supplied vehicle to suit.
What are you struggling with?
