abra-CAD-abra Posted September 4, 2019 Posted September 4, 2019 All, If I am iterating through the layer collection using vlax-for, how do I report an error only once? For example, if using the vla-put-linetype function with vl-catch-all-apply and vl-catch-all-error-p. If a particular linetype is not found for any number of layers, how would I report this once? Example below would return the variable em for every catch: (vlax-for l (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)) ) (setq em (vl-catch-all-apply 'vla-put-linetype (list l "My Linetype") ) ) (if (vl-catch-all-error-p em) (princ (strcat "\nLinetype " "My Linetype" " Not Found. ")) ) ) Thanks in advance.. Quote
dlanorh Posted September 4, 2019 Posted September 4, 2019 I'm not a big fan of (vl-catch-all-apply) and (vl-catch-all-errors-p). IMHO it is the lazy way of programming. At the start of your lisp check if the linetype is present in the drawing. Since "continuous" is always present in a new drawing (tblsearch "ltype" "continuous") should return the linetype definition. Thus, if you send a list of required linetypes (lt_lst) to the below (foreach l_typ lt_lst (cond ( (not (tblsearch "ltype" l_typ)) (setq missing (cons l_type missing)))) );end foreach it should return a list (missing) of the line types not in the drawing, or you could alter the routine to load the linetype. The same should apply to layers, text, *leader... styles. I they are not present create or load them. Quote
BIGAL Posted September 4, 2019 Posted September 4, 2019 Maybe (cond ( (not (tblsearch "ltype" l_typ)) (alert (strcat "Linetype " l_typ " has been skipped as missing")))) Quote
Grrr Posted September 4, 2019 Posted September 4, 2019 3 hours ago, abra-CAD-abra said: If I am iterating through the layer collection using vlax-for, how do I report an error only once? You could break the whole iteration process upon the first failed evaluation (so the behaviour would be like vl-some for collections) - (defun test ( / lt c ) (setq lt "My Linetype") (if (vl-catch-all-error-p (vl-catch-all-apply (function (lambda nil (vlax-for l (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) (setq c (vla-get-Name l)) (vla-put-LineType l lt) ) ) ) ) ) (print (strcat "Unable to put \"" lt "\" on layer \"" c "\"")) ) (princ) ) (test) 3 hours ago, abra-CAD-abra said: If a particular linetype is not found for any number of layers, how would I report this once? If you want to check if the linetype property of a layer object matches "My Linetype", then use vla-get-Linetype instead of vla-put-Linetype, And again you can print the first layer that doesn't match the criteria and break the iteration - (defun test ( / err lt c ) (setq lt "Continuous") (and (vl-catch-all-error-p (setq err (vl-catch-all-apply (function (lambda nil (vlax-for l (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) (and (/= (vla-get-LineType l) lt) (setq c (vla-get-Name l)) (exit) ) ) ) ) ) ) ) (= (vl-catch-all-error-message err) "quit / exit abort") (print (strcat "Layer \"" c "\" doens't contain linetype \"" lt "\"")) ) (princ) ) (test) Or if you want to print all the layers that don't match the criteria, then you'll have to iterate through all of them - meaning that you won't need the vl-catch-* functions - (defun test ( / lt c ) (setq lt "Continuous") (vlax-for l (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) (and (/= (vla-get-LineType l) lt) (setq c (cons (vla-get-Name l) c)) ) ) (if c (print (strcat "Layers \"" (substr (apply 'strcat (mapcar '(lambda (x) (strcat "," x )) c) ) 2 ) "\" do not contain linetype \"" lt "\"" ) ) ) (princ) ) (test) Quote
abra-CAD-abra Posted September 5, 2019 Author Posted September 5, 2019 Guys, Thank you all for your responses. I will study the options presented. Grrr, thank you for your detailed explanations and options Quote
