Sooshiant
Repair a LISP
Sooshiant
I have a lisp to type Persian in AutoCad 2019, but it has a bug and turn blipmode on every time I run it. I attached it to this post. Can any body help to repair it?
Thanks
KATEB.LSP
Share this post
Link to post
dlanorh
Thanks
Attached.
KATEB1.LSP
  • Thanks 1
Share this post
Link to post
Sooshiant
Great Job  👏👏👏
It has repaired. You're a geneous.
How should I thank you?
Share this post
Link to post
dlanorh
19 hours ago, Sooshiant said:
Great Job  👏👏👏
You need to be aware that the error routine within this lisp will replace autocad error routine for the duration of the drawing session. It should really be inside the (defun c:..) routines where it is reset when the lisp finishes. I didn't want to move this as it would have broken any other routines that relied on it. I did however convert it's command calls to command-s calls as they would trigger spurious  "(*pop-error-mode*) underflow" errors.
  • Thanks 1
Share this post
Link to post
