SlalomeVr Posted September 7, 2019 Posted September 7, 2019 Hello I'm trying to update this code to draw only closest lines from block, but I'm blocking with the function "LineToCurve " to return the smallest distance and draw only closest lines from point. Can you help me please, see attached dwg . Thanks in advance (defun C:linetoblk ( / curve curves blk doc pt1 pt2 ss1 vec ) (defun KGA_Conv_Pickset_To_ObjectList (ss / i ret) (if ss (repeat (setq i (sslength ss)) (setq ret (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) ret)) ) ) ) (defun KGA_List_Divide_3 (lst / ret) (repeat (/ (length lst) 3) (setq ret (cons (list (car lst) (cadr lst) (caddr lst)) ret)) (setq lst (cdddr lst)) ) (reverse ret) ) (defun KGA_Sys_ObjectOwner (obj) (vla-objectidtoobject (vla-get-database obj) (vla-get-ownerid obj)) ) (defun LineToCurve (sta vec curves / end line ptLst) ;PROBLEM I would like modify this function to draw only the shortest line from curves to the block (foreach curve curves (setq line (vla-addline (KGA_Sys_ObjectOwner curve) (vlax-3d-point sta) (vlax-3d-point (mapcar '+ sta vec)) ) ) (if (setq ptLst (KGA_List_Divide_3 (vlax-invoke line 'intersectwith curve acextendthisentity))) (progn (setq end (car ptLst)) (foreach pt (cdr ptLst) (if (< (distance sta pt) (distance sta end)) (setq end pt) ) ) (vla-put-endpoint line (vlax-3d-point end)) line ) (progn (vla-delete line) nil ) ) ) ) (if (and (princ "\nSelect curves ") (setq curves (KGA_Conv_Pickset_To_ObjectList (ssget '((0 . "LINE,*POLYLINE"))))) (princ "\nSelect blocks: ") (setq ss1 (KGA_Conv_Pickset_To_ObjectList (ssget '((0 . "INSERT"))))) (setq pt1 (getpoint "\nFirst point for verticale direction: ")) (setq pt2 (getpoint pt1 "\nSecond point for verticale direction: ")) ) (progn (setq vec (trans (mapcar '- pt2 pt1) 1 0 T)) (foreach blk ss1 (LineToCurve (vlax-get blk 'insertionpoint) vec curves) ) )) ) dwgfortest.dwg Quote
Roy_043 Posted September 8, 2019 Posted September 8, 2019 (edited) Original topic: Revised code: (defun KGA_Conv_Pickset_To_ObjectList (ss / i ret) (if ss (repeat (setq i (sslength ss)) (setq ret (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) ret)) ) ) ) (defun KGA_List_Divide_3 (lst / ret) (repeat (/ (length lst) 3) (setq ret (cons (list (car lst) (cadr lst) (caddr lst)) ret)) (setq lst (cdddr lst)) ) (reverse ret) ) (defun KGA_Sys_ObjectOwner (obj) (vla-objectidtoobject (vla-get-database obj) (vla-get-ownerid obj)) ) (defun LineToCurve (sta vec curveLst / end line ptLst) (setq line (vla-addline (KGA_Sys_ObjectOwner (car curveLst)) (vlax-3d-point sta) (vlax-3d-point (mapcar '+ sta vec)) ) ) (if (setq ptLst (KGA_List_Divide_3 (apply 'append (mapcar '(lambda (curve) (vlax-invoke line 'intersectwith curve acextendthisentity)) curveLst ) ) ) ) (progn (setq end (car ptLst)) (foreach pt (cdr ptLst) (if (< (distance sta pt) (distance sta end)) (setq end pt) ) ) (vla-put-endpoint line (vlax-3d-point end)) line ) (progn (vla-delete line) nil ) ) ) (defun c:LinesToCurves ( / blkLst curveLst doc pt1 pt2 vec) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-endundomark doc) (vla-startundomark doc) (if (and (princ "\nSelect curves: ") (setq curveLst (KGA_Conv_Pickset_To_ObjectList (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*LINE"))))) (princ "\nSelect blocks: ") (setq blkLst (KGA_Conv_Pickset_To_ObjectList (ssget '((0 . "INSERT"))))) (setq pt1 (getpoint "\nFirst point for direction: ")) (setq pt2 (getpoint pt1 "\nSecond point for direction: ")) ) (progn (setq vec (trans (mapcar '- pt2 pt1) 1 0 T)) (foreach blk blkLst (LineToCurve (vlax-get blk 'insertionpoint) vec curveLst) ) ) ) (vla-endundomark doc) (princ) ) Edited September 8, 2019 by Roy_043 Quote
