harinezumi Posted September 9, 2019 Posted September 9, 2019 (edited) hallo, I was trying to put a lisp in a menu macro that would place the current date in the clipbpard. I started from this example that places the file name in the clipboard: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/copy-string-to-clipboard/m-p/5607258#M331744 and I changed (getvar 'dwgname) to (menucmd "M=$(edtime,$(getvar,date),DD.MO.YY)") to end up with (vlax-invoke(vlax-get(vlax-get (vlax-create-object "htmlfile")'ParentWindow)'ClipBoardData)'setData"TEXT"(menucmd "M=$(edtime,$(getvar,date),DD.MO.YY)")) (sorry: one line to accomodate the macro CUI) While the original worked perfectly (and mine one too from the command line) as a menu macro this one hangs when it reaches the first $, so I guess there must be some conflicts putting Diesel inside and outside a lisp in a macro... Can someone help? Can I do it without lisp? Thank you Edited September 9, 2019 by harinezumi Quote
tombu Posted September 10, 2019 Posted September 10, 2019 You could define it as a function in acaddoc.lsp and use that function in the macro. Quote
