whosa
Round Down 0.50
whosa
Hi Guys,
i would like to add a round down 0.50 to this lisp.
 ex. 15.15 = 15.00 -  15.60=15.50
Exception <0.50 slould be =0 .50 (not 0.00)
It is possible?
Someone can help me?
many thanks
(defun C:but ( / e o p d )
	(setvar 'errno 0)
	(and
		vlax-get-acad-object
		(while (/= 52 (getvar 'errno))
			(setq e (car (nentsel "\nSelect text to fill: ")))
			(cond
				((= 7 (getvar 'errno))
					(princ "\nMissed, try again.") (setvar 'errno 0)
				((and e (not (vlax-property-available-p (setq o (vlax-ename->vla-object e)) 'TextString)))
					(princ "\nThis is not a text object.") (setq e nil)
				((and o (eq (vla-get-Lock (vla-item (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) (vla-get-Layer o))) :vlax-true))
					(princ "\nThis object is on a locked layer.") (setq e nil)
				(e
					(if
						(and
							(setq p (getpoint "\nSpecify first point: "))
							(cadr (setq p (cons p (list (getpoint "\nSpecify second point: " p)))))
							(setq d (rtos (abs (/ (apply '- (mapcar 'last (mapcar '(lambda (x) (trans x 1 0)) p))) 1000.)) 2 2))
						(cond
							( (= "ATTDEF" (cdr (assoc 0 (entget e)))) (vla-put-TagString o d) )
							( T (vla-put-TextString o d) )
					(setvar 'errno 52)
				(T nil)
);| defun |; (or vlax-get-acad-object (vl-load-com)) (princ)
Share this post
Link to post
whosa
thanks for your reply. I found this fix but i don't understand how i can add it on my lisp.
Share this post
Link to post
Lee Mac
Copy the function definition to the end of your code, and then change this:
To:
(setq d (rtos (LM:rounddown (abs (/ (apply '- (mapcar 'last (mapcar '(lambda (x) (trans x 1 0)) p))) 1000.)) 0.5) 2 2))
@Emmanuel Delay Thanks for the recommendation :thumbsup:
Edited by Lee Mac
  • Like 2
Share this post
Link to post
whosa
To:
Thanks, work really well.
I would like to ask you:
  1. Is it possible to round UP just when the value is <0.50?
  2. Is it possible to get a planar distance between two point insted the height value using the same structure of the lisp?
Thank a lot.
Share this post
Link to post
Lee Mac
Copy the definition for my LM:roundup function to the end of your code, and then change:
to:
(setq d (abs (/ (apply '- (mapcar 'last (mapcar '(lambda (x) (trans x 1 0)) p))) 1000.))
      d (rtos ((if (< d 0.5) LM:roundup LM:rounddown) d 0.5) 2 2)
  1. Is it possible to get a planar distance between two point insted the height value using the same structure of the lisp?
Copy the function definition for the main program, change the syntax of the copied definition from c:but to c:somethingelse, and change:
to:
(setq d (abs (/ (apply 'distance (mapcar '(lambda ( x ) (list (car x) (cadr x))) p)) 1000.))
This will calculate the 2D distance between the points in the UCS plane.
Share this post
Link to post
whosa
Thanks a lot. You are the guru of the LIPS.
I will try it on Monday.
Thanks
Share this post
Link to post
Lee Mac
You're most welcome and thank you for your compliments - let me know how you get on.
Share this post
Link to post
