pmadhwal7
zoom to particular area
pmadhwal7
Sir,
I need help that I want a lsp which allow me to zoom in particular area in all layouts tabs at once.
Edited by pmadhwal7
Share this post
Link to post
Tharwat
An example.
;; Where the variables p1 & p2 are a list of coordinates
(foreach l (layoutlist)
  (setvar 'CTAB l)
  (vlax-invoke (vlax-get-acad-object) 'ZoomWindow p1 p2)
  ) (vl-load-com)
Share this post
Link to post
pmadhwal7
Sir example and error both are in attachment just like this I want to zoom in all layouts tabs in particular area..
Share this post
Link to post
Tharwat
How did you feed the two points and ran the codes ?
Share this post
Link to post
pmadhwal7
I just copy your code and paste it to lsp file extension and just ran this than the error occurred...
Share this post
Link to post
Tharwat
You need to feed the coordinates as I have mentioned in the first port. p1 & p2
eg:
(setq p1 '(0. 0. 0.))
(setq p2 '(10.0 10.0 0.0))
  (setvar 'CTAB l)
(vl-load-com)
Share this post
Link to post
pmadhwal7
But sir their are lots of layouts tabs in my drawing and as per your method if I feed manually all the coordinates than better to go one by one in all layouts
Share this post
Link to post
pmadhwal7
Sorry sir don't be angry I have and lsp which allow me to zoom extended in all layouts similarly I just want to zoom it in particular area I also retry your lsp but again error massage occurred..
Share this post
Link to post
Tharwat
My replies have nothing to do anger, so here are a few questions for you to drag and push the idea to your world.
- How do you make a zoom window in AutoCAD ?
- Can you zoom window without picking two points?
Share this post
Link to post
lrm
Perhaps this will help.
1.  Give the command appload and load zlayout.lsp
2. Give the command zlayout.
Note, you will be view the same area of a layout for any one you choose.  If you want to zoom to a different window than the one defined 0,0,0 to 1,1,0, then change the values for p1 and p2 to the lower left and upper right corners of the desired window.
(defun c:zlayout (/)
(setq p2 '(1.0 1.0 0.0))
  (setvar 'CTAB l)
(vl-load-com)
BTW, you can use the PrtScn keyboard button on your keyboard to copy the screen image to the clipboard.  Alt-PrtScn will copy the image of the currently active application.  Better yet, use the Windows 10 Snipping Tool.
zlayout.lsp
Share this post
Link to post
CHLUCFENG
May I offer an alternate solution for the user, using the code that Tharwat and lrm already started?
(defun c:zlayout (/ sSize vSize vCtr LLC URC)
  (vl-load-com)
  (setvar "tilemode" 0)
  (vl-cmdf "pspace")
  (graphscr)
  (princ
    "\nZoom to the area you would like viewed on all tabs. Press <ENTER> when ready... "
  (getstring)
  (setq	sSize (getvar "screensize")
	vSize (getvar "viewsize")
	vCtr  (getvar "viewctr")
  (setq	LLC
	 (mapcar '-
		 vCtr
		 (list (* (* 0.5 vSize) (/ (car sSize) (cadr sSize)))
		       (* 0.5 vSize)
		       0.0
  (setq	URC
	 (mapcar '+
		 vCtr
		       (* 0.5 vSize)
		       0.0
    (setvar 'CTAB l)
    (vlax-invoke (vlax-get-acad-object) 'ZoomWindow LLC URC)
Run this code, get your zoom area on one sheet, then it will use the same zoom for all sheets.
Share this post
Link to post
CHLUCFENG
I suppose I have it setup where any key will work, not just enter.
This version will pause on each tab so you can check whatever is in the view prior to jumping to the next.
  (vl-load-com)
  (vl-cmdf "pspace")
  (graphscr)
  (princ
    "\nZoom to the area you would like viewed on all tabs. Press any key when ready... "
  (getstring)
  (setq	LLC
	 (mapcar '-
		 vCtr
		       (* 0.5 vSize)
		       0.0
  (setq	URC
	 (mapcar '+
		 vCtr
		       (* 0.5 vSize)
		       0.0
  (setvar "nomutt" 1)
    (setvar 'CTAB l)
    (princ
      "\nPress any key to continue... "
    (getstring)
  (setvar "nomutt" 0)
Share this post
Link to post
pmadhwal7
  (setvar 'CTAB l)
(vl-load-com)
zlayout.lsp 197 B · 0 downloads
working fine...
Share this post
Link to post
pmadhwal7
  (vl-load-com)
  (vl-cmdf "pspace")
  (graphscr)
  (princ
  (getstring)
  (setq	LLC
	 (mapcar '-
		 vCtr
		       (* 0.5 vSize)
		       0.0
  (setq	URC
	 (mapcar '+
		 vCtr
		       (* 0.5 vSize)
		       0.0
  (setvar "nomutt" 1)
    (setvar 'CTAB l)
    (princ
    (getstring)
  (setvar "nomutt" 0)
this is also working fine...thanks a lot to all sir
Share this post
Link to post
