Help
Beginner bob
1163eda71867f5eaaa5dbbf628457c25-full.pni need to replicate this in autocad can anyone help me? im a total beginer and dont know much. i have no idea how to make those dashed lines and how to know the lenght of 2 middle lines, as well as how to posision circkles up top.
Link to post
Dashed lines use a linetype that is dashed just happens that is what one is called, you may need to change linetype scale use properties.
The circles appear to be at 45 degrees form centre.
The verticals appear to match the top circles centres so draw a line from centre of each this will give top of line.
Use offset for dashed line, use Intersection snap to find center of circles.
  • Thanks 1
Link to post
The dashed lines are called Center lines.
Doesn't appear to have all of the information, you'll need to insert in AutoCAD and scale it using Reference option and one of the given dimensions. Search here for Scale Reference and inserting Images, etc.
Link to post
