not sure if this will work or not, but u could give it a try while waiting on lee mac lol
replace in2ft in the code he gave you with this and let me know how that outputs
(defun in2ft (num / ft in)
(setq ft (fix (/ num 12.0))
in (rem num 12.0))
(strcat
(if (= (substr (rtos ft 2 2) ((strlen (rtos ft 2 2))-3)) ".00")
(rtos ft 2 0)
(rtos ft 2 2)
(chr 39) (chr 45)
(if (= (substr (rtos in 2 2) ((strlen (rtos in 2 2))-3)) ".00")
(rtos in 2 0)
(rtos in 2 2)
(chr 34)))
edit: nevermind lol, lee is on the job:wink:
  • Replies 23
  • Lee Mac
    14
  • cabltv1
    9
  • techjunkie09
    1
Thanks for the input, but there is a much simpler alternative junkie :P
I created that sub-function before I figured out that the rtos function, if provided with an argument of 3, will return the result I needed.
The trailing zeros are controlled by the DIMZIN sys var I believe :)
Lee
Lee,
I got it to work by changing the DIMZIN Variable to 8 or 12. Anything lower and there was no change.
The "Z" coords are missing 1 zero but I can live with that.
Thanks for the suggestion and the original code!
Techjunkie09,
Thanks for your suggestion but made no difference without changing the DIMZIN Variable.
